Old 10-18-2011, 12:09 AM   #1
norson
Default Model A parts book
Is there an on line parts book for Model A's. Does anyone sell a reproduction of same. Norm
norson is offline   Reply With Quote
Old 10-18-2011, 12:34 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Model A parts book
Check with Bert's, Bratton's, or Snyder's. Try to buy the 1931 Chassis Parts book, rather than the 1932. I have both, but like the 1931 because it has ONLY Model A parts.
Old 10-18-2011, 02:45 PM   #3
norson
I'm sorry, I wasn't clear. I'm looking for an Original parts parts book with the original part numbers for the original body parts. Ie. door parts, top parts, etc. I was a partsman for 40 years. It's kind of like a security blanket. Thanks. Norm
Old 10-18-2011, 02:54 PM   #4
JoeWay
JoeWay's Avatar
Pretty much the same answer. Snyder's catalog lists the Body Parts Book as their number BA-5, for $24 in the older catalog I have.
Joe
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 10-18-2011, 03:05 PM   #5
CarlG
CarlG's Avatar
This may be what you want ?? (Snyders P/N BA2 $9.75)
Every restorer should have this book to identify the chassis and motor parts by correct name and Ford number. It lists all of the chassis parts, along with the year each was used. Also tells correct hardware that was used for attaching each part. U.S.A.
Old 10-19-2011, 12:25 AM   #6
Tom Wesenberg
The book Carl just pictured is a "must have". I also have the body parts book, but never use it. It has no pictures for reference. My body parts book is an original and I think I bought it on ebay years ago.
Old 10-19-2011, 10:47 AM   #7
Charlie Stephens
One thing you need to keep in mind for slightly later parts books is that Ford used all new part numbers for the Model B (this was the last time Ford would change the part number for a new model when the part itself was the same). If a part used on a Model A (and started with the prefix "A") was carried over (as the identical part)to the 1932 it would carry a "B" prefix on the part number. If a part was not carried over it would carry the "A" prefix. Another danger lurking in parts books is that they were intended to allow the dealers to keep the cars running (not to "restore" them) and changes in parts that allowed the parts to remain functionally interchangeable did not result in a new part number (such as changing from a stamping to a forging).
Charlie Stephens
Old 10-19-2011, 03:53 PM   #8
Brad in Germany
Brad in Germany's Avatar
Here is the one I use:
Fordially,
Brad in Germany now in Maryland
Brad in Germany is offline   Reply With Quote
Old 10-29-2011, 11:41 PM   #9
norson
Thanks. Finally got back to get the answer. The first answer was correct. My bad. Thanks for all the help. Norm
Old 12-25-2023, 10:38 PM   #10
RHD
RHD's Avatar
I have a repro copy here. Please email [email protected]
R.H.D.
Silence is golden unless you have kids, then silence is suspicious.
RHD is offline   Reply With Quote
