10-17-2011, 03:30 PM | #1 |
12 volt or 6 volt coil how to tell difference
I have several coils that are either 12 volt or 6 volt. They are not marked and I was wondering how you can tell the difference?
There must be an ohms reading that would give some indication. Any help would be appreciated. I don't wanrt ot just hook them up to a 12 volt battery and burn them out if they are 6 volt. |
10-17-2011, 03:57 PM | #2 |
Re: 12 volt or 6 volt coil how to tell difference
You won't burn out the coils, but here is an easy way to tell..
Hook 12v power to 1 side of the coil, and then check the voltage on the other side.. H (hook to + and check output on - for instance, the polarity for the test is not important and won't hurt either way) _+_[]_-_ | | | | | | | | |______| 12v through a 12v coil will still show 12v when it comes out the other post of the coil, however a 6v coil will drop the voltage to 6v.. I have used old 6v coils as voltage reducers before for intermittent items in a 12 v system, like a horn or other item - Dave in Boise |
10-17-2011, 06:01 PM | #3 |
Thank You Dave.
10-18-2011, 12:28 AM | #4 |
You need to connect an amp meter in series with the coil and 6 volt battery. A 6 volt coil will draw 4 amps.
10-18-2011, 04:15 AM | #5 |
If you have an accurate ohm meter, reading across the posts of a 12 volt coil should be about 3 ohms. A 6 volt coil is about half of that. It is not an exact number, but close enough that you can tell 6 from 12 volt.
Or, doing what Tom says, a 12 volt coil will flow about 2 amps if connected to 6 volts. Instead of an accurate ohm meter, you need an accurate ammeter (that can tell the difference between 4 amps vs. 2 amps).
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
10-18-2011, 08:16 AM | #6 |
10-18-2011, 08:49 AM | #7 | |
That and Tom usually knows his stuff |
10-18-2011, 09:16 AM | #8 |
12 volt coils are actually 6 volt coils with a resister connected in series within the primary circuit usually internal to the coil. That fact allows you to check the ohms across the primary terminals to see what the resistance is of the coil. As mentioned above a 6 volt coil should have less than 2 ohms and a 12 volt coil will have more closer to 2.5 to 3 ohms of resistance
10-18-2011, 09:38 AM | #9 | |
10-18-2011, 09:58 AM | #10 |
How many amps does a 12 volt coil draw using a 12 volt battery? |
10-18-2011, 10:38 AM | #11 |
That would be a problem. I assume we are talking about old coils laying around of questionable conditon and you don't want to buy a decent ohm meter just to see if you have 6 or 12 volt coils? In that case I would recommend tossing the coils in the trash and buying a new one 6 volt coil at autozone for only $16.00.
10-18-2011, 10:41 AM | #12 |
10-19-2011, 12:42 AM | #13 | |
I find 6 volt coils at most swap meets and don't recall buying a bad one yet. That's because so many coils are needlessly replaced. |
10-29-2011, 08:47 AM | #14 | |
OK, I didn't make myself clear. If I have a coil and all it says is 12v or nothing, How can I check it to determine if I use it on a 12v as is or put a resistor in line? Last edited by ldj1002; 10-29-2011 at 08:55 AM. |
10-29-2011, 09:11 AM | #15 |
Read across the primary posts with an ohm meter. If it reads about 3 ohms, you can use it on a 12 volt car without an external resistor. If it reads about 1.5 ohms, you need an external resistor.
10-29-2011, 10:52 AM | #16 |
Thanks very much
10-29-2011, 04:50 PM | #17 |
Is the mallory available for 6 volt? I'm about to put a B motor w OHV & t-5 in my '31 roadster. It's hard to sleep nights !
LazloBassett Because a bottle in front of me IS better than a frontal lobotomy |
10-30-2011, 08:15 AM | #18 |
Oops! Wrong thread.
10-30-2011, 10:35 AM | #19 |
you can delete any of your posts. click on the EDIT button and then DELETE.
10-31-2011, 09:49 PM | #20 |
NO such thing as a 6 volt or 12 volt coil. You need to match the impedience of what your working with. Iceman
