05-08-2010, 01:22 PM | #1 |
Converting back from Rumble seat to Trunk
How dificult is it to convert back from Rumble seat to Trunk?
Can I just turn the Decklid? Thanks Joop |
05-08-2010, 01:43 PM | #2 |
Re: Converting back from Rumble seat to Trunk
Just to get you started. change the hinges. move the handle weld up the old hole. drill a new one. change the curved inner panel . that will keep you busy for a few days
05-08-2010, 02:27 PM | #3 |
Yes, not too difficult. I have just done it to my coupe. You will see it in the fall.
Make sure to get the "good hinges" at Arizona Model A. Frank |
05-08-2010, 02:33 PM | #4 |
You also need to change the curved rear pannel to one for a trunk. I did the oposite when I change my car from a trunk to a rumble. The Les Andrews Model A mechanic Vol II has everything including the parts list. If you can, borrow or buy a copy. Not a hard job at all though.
05-14-2010, 10:02 PM | #5 |
Are these inner panels 1928-29? They don't line up with any holes on a 30-31 subrail crossmember. not one has dimples the other doesn't
05-14-2010, 10:42 PM | #6 |
