#1 |
Is there a easy way of finding the gear ratio of a A rear end
#2 |
I just saw this the other day on here... mark one of the rear tires with chalk at the 6 o'clock position; remove the spark plugs; put the car in third gear; hand crank the car, in gear, until the rear marked wheel makes one complete revolution back to 6 o'clock. Count the number of engine revolutions to do this and there's your gearing.
#3 |
Is there not a number stamping on the differential housing like the early V8's?
#4 | |
![]() Quote:
Nope. The early differential housings that had a 3.70 were sometimes stamped but generally the "marking" is on the speedometer drive gear cap. |
#5 | |
![]() Quote:
Fred Kroon 1929 Std Coupe 1929 Huckster |
#6 |
Steve |
#7 |
Thanks Steve.
#8 |
i was wondering weather there was a number on the housing ,,i knew about the speedo housing number......there are a couple for sale but i would like to know the ratio ...they are quite a drive to see them
