Old 09-11-2011, 06:13 PM   #1
d.j. moordigian
d.j. moordigian's Avatar
Default Tire Pump A-17053 A-1
I have a Ford tire pump with a 3/8" hole about 6.5" up from the cast
base. Seems dumb, but, is that correct?
How is the tube attached to the base? Somebody soft soldered it, not
a clean job !
Thanks, Dudley
d.j. moordigian is offline   Reply With Quote
Old 09-11-2011, 06:17 PM   #2
31Tudor
31Tudor's Avatar
Default Re: Tire Pump A-17053 A-1
There is not a hole in the tube. The tube was seemed, vertically, and is sometimes difficult to see, but no hole in the tube. The base was perhaps pressed on, if it was soldered, the solder would not show.
31Tudor is offline   Reply With Quote
Old 09-11-2011, 07:29 PM   #3
d.j. moordigian
31Tudor, thank you.
Old 09-12-2011, 02:51 PM   #4
d.j. moordigian
Thanks Don,
The pump I have is of the first, in your first photo(single Ford script), everything
matches except for that darn hole and the poor solder job. When I get some time
I going to fix it up.
Old 09-12-2011, 03:29 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Originally Posted by d.j. moordigian View Post
Thanks Don,
If I read Dons post correctly, since you have a CAST steel base, the tube should have threads on both sides and no solder or brazing.
Still wondering about the hole? Why would it be there?
Old 09-12-2011, 03:31 PM   #6
Mike V. Florida
Originally Posted by Don Turley View Post
The Model A tire pumps with a cast steel base had a 1-1/4" outside diameter metal cylinder tube with a seam that ran lengthwise of the tube and was threaded at both ends of the tube. The bottom end screws into the cast base and a cap screws onto the top end.
The Model A tire pumps with a stamped steel base had a 1-1/4" outside diameter metal cylinder tube with a seam that ran lengthwise of the tube and was threaded at the top end of the tube. The bottom end is brazed to the stamped steel base and a cap screws onto the top end.
There was no hole drilled into the steel cylinder tube.
Some of the cast steel bases have Ford script on one side only. Some of the cast steel bases have ribs on both sides, with a similar look to the stamped steel bases that have ribs. Some stamped steel bases have four ribs and some have five ribs.
Cast steel bases with Ford script on both sides are Model T.
Tire pumps with a cylinder tube larger than 1-1/4" are not considered correct for MARC & MAFCA Fine Point Judging.
First photo, left to right: (1) early pump with cast base and Ford script on one side. (2) cast steel base with ribs. (3) stamped steel base with five ribs. (4) stamped steel base with four ribs.
Second photo: Bottom view of stamped ribbed steel base on left, and cast ribbed base on right.
Third photo: Stamped steel ribbed bases. Five ribs on left, four ribs on right.
Don, did only the first type (threaded cylinder) have the tube out of brass?
Old 09-12-2011, 04:44 PM   #7
Mike V. Florida
Don, Thanks for clearing that up for me!!
Old 09-12-2011, 07:26 PM   #8
d.j. moordigian
The threaded tube to base tells me a lot about the repair, the hole is dumb.
If you get it for free you can't snivel.........much.........thanks.
