#1 |
I have a Tilliston Carb and although the engine is running great and I seem to have eliminated all the air leaks, etc. Everything seems to be tight so should I remove the carb and re-adjust the float level?
I still get Poppin' when backing down from a higher speed to a lower speed and between gears. (P.S. I also get gasoline fume smells when I shut the engine off.) IT IS DRIVING MY WIFE NUTS.....) I'M AFRAID I'LL LOOSE MY 50+ YEARS ALLOWANCE IF I CAN'T GET THIS FIXED..... |
