Old 08-17-2011, 12:55 AM   #1
40Pickup
40Pickup's Avatar
Default 1934 Pitman Arm, Identification Help .....
Need help to identify -34 Pitman arm or arms if there is more than one of them, preferably with pictures and dimensions, and the difference between 1932 and 1933-34 so I can sort them out
Is there anyone who would like to help me with this!
Thank you in advance, Jorgen
40Pickup is offline   Reply With Quote
Old 08-17-2011, 07:58 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 1934 Pitman Arm, Identification Help .....
32's ball and arm separate.33-34's ball and arm are forged as a unit.Look for a part number.33-34's start with a 40- and 32's start with a B-.Hope this helps.
deuce lover is offline   Reply With Quote
Old 08-17-2011, 01:35 PM   #3
DavidG
DavidG's Avatar
There is an early '33 version where the arm and ball stud are separate parts, but these have a promonant raised '40' prefix part number forged into the side of the arm to help distinguish them from the very similar-looking '32 arm.
Old 08-17-2011, 01:59 PM   #4
bobH
One more thing to add to DL's post, above.... The part numbers are a good indicator, and there is one more -- 46-. The 46- is for pickups/commercials, and looks the same as a 40-, but has slightly different 'clocking' to compensate for the different steering column angle on pickups. There might also be a BB- for big trucks - don't know about that. And, there is also a possibility of NO part number on the arm. I happen to have one of these, and in that case I believe you are sol for identification. All I can say is that the one I have is surely a 40- arm, as it fits & functions correctly on my 34 (passenger).
To be a little more 'inclusive', there is also a RHD pitman arm. I have one, and it does not have a part number on it ( and I don't know the part number prefix). If you put all of these arms side-by-side ( the 40- , 46- , & RHD ) they would all look the same to the casual observer. You would have to study them carefully to see the 'clocking' difference, and the slightly different 'ball-angle' on the RHD. Hope this helps.
bobH is offline   Reply With Quote
Old 08-17-2011, 02:12 PM   #5
Seth Swoboda
Seth Swoboda's Avatar
1932 pitman arm part number is B-3590-A for passenger and commercial. 1933-34 pitman arm part number for passenger is 40 3590 and 46 3590 for commercial. The part numbers should be stamped on the pitman arm.
Seth Swoboda is offline   Reply With Quote
Old 08-17-2011, 03:26 PM   #6
bobH
33 - 34 Passenger Pitman Arm.... About 5-1/2, center-to-center, about 1-in Hole
Old 08-17-2011, 04:24 PM   #7
Tim Brown
Tim Brown's Avatar
I have an extra 34 pitman arm if anyone needs one. PM me...
Tim Brown is offline   Reply With Quote
Old 08-17-2011, 04:27 PM   #8
Floyd
To clear up info from an above post, the pitman arm for 32 passenger is B 3590A and the arm for commercial (pickups) is B 3590B which has different clocking. The A version is stamped A, and the B version does not carry a letter stamp.
Floyd
Floyd is offline   Reply With Quote
Old 08-17-2011, 06:12 PM   #9
DavidG
DavidG's Avatar
In my experience, the 1932 'B' suffix arm is also stamped with that letter.
Old 08-18-2011, 01:38 PM   #10
40Pickup
40Pickup's Avatar
Thank you all for your replies, and "bobH" for picture. Jorgen
Old 08-20-2011, 01:08 AM   #11
40Pickup
40Pickup's Avatar
PM sent! Jorgen
