Old 08-02-2011, 04:42 PM   #1
svm99
Default '28/'29 Repro Cowl Patch Panels?
I need to replace the lower sections of my cowl panels. Are the repro patches formed with the correct panel curves or should I just start forming my own from scratch? I've heard some say the complete repro panels are a lot of work to install also. Any body have experience with these?
Thanks, Paul
svm99 is online now   Reply With Quote
Old 08-02-2011, 05:25 PM   #2
Bassman/NZ
Bassman/NZ's Avatar
Default Re: '28/'29 Repro Cowl Patch Panels?
I used the complete panels. I thought it would be easier than welding in the patches..... I think in the end it may have been easier to use the patches. The complete panels are unfinished, they're certainly not a bolt in fit. If you are good at sheetmetal welding and finishing, I would recommend the patches.
Bassman/NZ is offline   Reply With Quote
Old 08-02-2011, 05:29 PM   #3
29restorod
29restorod's Avatar
To me its a lot easier to just replace the hole quarter. Use a spot weld cutter to cut the spot welds free,and use the same cutter to cut matching holes in the new panel. Mig weld the spots and grind down,no body work. its even easier if the firewall is out of the car already.
If you think SBC's are "Old School" you are not old enough.
29restorod is offline   Reply With Quote
Old 08-02-2011, 05:56 PM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Thanks, Paul
Paul, how picky are you going to be, ...and what are your expectations? On a scale of 1 - 10, my experiences are they are about a 7½ to 8 on shape. THAT may be good enuf for your needs. They can be worked to get the shape even closer if you have a 'wheel', or a planishing hammer & dolly.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 08-02-2011, 06:10 PM   #5
Fred K-OR
Fred K-OR's Avatar
I had no experience is patching panels so I just looked for some good used panels. I found some good one but had to do a little bit of patching. They fit, had no problems with them and they look great.
If you do want to go with used panels, may want to try Bert's in Denver.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 08-03-2011, 08:39 AM   #6
svm99
Is Bert's a Model A parts seller?
Paul J.
Old 08-03-2011, 09:17 AM   #7
Special Coupe Frank
Special Coupe Frank's Avatar
Paul J.
Yep. New and used parts.
They have an excellent reputation.
Special Coupe Frank is offline   Reply With Quote
Old 08-03-2011, 09:58 AM   #8
Jack 34pu
Jack 34pu's Avatar
Just picked up a lower patch panel set from Bratton"s (great people to deal with) and the metal shaping is not that great. You will have to hand form somewhat to get the shape perfect. My original cowl panel curved edge is pretty sharp while the patch is more rounded. It will take some hammer work to get it right. (sold in pairs only)
Jack 34pu is offline   Reply With Quote
Old 08-03-2011, 03:25 PM   #9
Fred K-OR
Fred K-OR's Avatar
Paul J.
Yes and phone is 800-321-1931, web is www.modelastore.com with email [email protected].
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 08-03-2011, 06:11 PM   #10
svm99
Thanks for all the info. I'll give Bert's a call tomorrow and check on some parts. I looked at their site, quite a bunch of stuff, I hadn't heard of them before.
Paul J.
Old 08-03-2011, 08:34 PM   #11
wrndln
If the rusted out areas are not real large (wider than 5 or 6"), I would cut the rusted area out and MIG or TIG weld in a homemade patch using 20 ga sheetmetal. If you cut the patch first, then lay it on the area to be patched, you can trace around the patch piece and then with a die grinder, cut the area in the cowl panel. I have done 2 or 3 this way and they turned out well, and used very little filler to finish the cowl. I feel the original sheetmetal is better than any repro patches or whole panel. Most sheetmetal I have found, doesn't fit or look right. Just my opinion. If you would like to see a few pictures of the patching I did, send me a PM.
Rusty Nelson
Old 08-04-2011, 05:10 PM   #12
bobscogin
My thinking too, and that's what I did. I used Howell's cowl panels and they fit well.
Bob
bobscogin is offline   Reply With Quote
Old 08-05-2011, 11:45 AM   #13
svm99
Fred, thanks for the lead, I've got a pair on the way from Berts. Very fair people to deal with on the phone thus far.
Thank you to all for your responses, hopefully saved me some effort.
Paul J.
