Old 07-28-2011, 07:34 AM   #1
sidevalve
sidevalve's Avatar
Default battery tray and mount kit
I just got my battery tray and stud mounting kit from Snyders. This is going into a car that doesn't have one yet and I want to install it correctly but have no instructions. Can any one send me some pictures of the setup? Thanks.
Matt from central Jersey
sidevalve is offline   Reply With Quote
Old 07-31-2011, 08:27 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: battery tray and mount kit
I thought someone would have posted a good picture by now, but then I didn't have any pictures either. I took these two pictures yesterday of an original battery mount in a 1928 frame. This has the forged mounts, so will be a little different than your repro mount. Some repro mounts (maybe all, I don't know for sure) have a poor bend in the top mount to frame area, and they can only be used by mounting on the underside of the frame rail.
The ground strap is missing, but you can see the ground cable mounting bolt head in the top picture to the left of the empty hole. The empty hole is where the ground strap mounted on the early 28's when the battery posts were on the other corners.
Old 07-31-2011, 10:34 PM   #3
Elcastor
Elcastor's Avatar
Tom, maybe I am missing something, but how would you put a nut on those posts?
Ben Purkey
Mexico and the Pacific NW
http://www.martin-parry.com/
Elcastor is offline   Reply With Quote
Old 08-01-2011, 04:58 AM   #4
Tom Wesenberg
I was wondering the same thing after posting the pictures. This 1928 car was cut into a pickup and really beat up, then left to rust in the woods. I suppose the two studs are bent a little.
Old 08-01-2011, 05:44 AM   #5
Tom Wesenberg
Here's 4 pictures comparing an original mount to a repro mount. As you can see by the incorrect bend at the top, the repro mount can NOT be mounted on top of the lower frame lip, as the original is mounted. The only way to use this repro battery tray is to mount it to the bottom side of the lower frame lip. Maybe these pictures will help you with the installation of your new battery mount.
Old 08-01-2011, 07:47 AM   #6
sidevalve
sidevalve's Avatar
Thanks Tom, those pictures are very helpful. Big difference in the repop one from the original one like you said. Mine mounted very sloppy. I will take your advice and mount it under the frame. On a good note, I was able to start the motor for the first time this weekend. It runs like a dream.
Old 07-26-2017, 10:03 PM   #7
steve warren
How do I view your photos do I have to get a photobucket account
steve warren is offline   Reply With Quote
Old 07-27-2017, 02:31 AM   #8
Tom Wesenberg
Yes, now photobucket sucks worse than they used to when they changed about 5 years ago, and I lost over 1000 pictures. Some day I will have to fire up my old computer and load all my pictures to a card.
Old 07-26-2017, 11:15 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
Steve, Unfortunately Photobucket is the problem, Not you!!!
