Old 07-27-2011, 05:15 PM   #1
barry
Default alternate 32 V8 carburetor
I have an original 32 V8 engine with a detroit lubricator carb. what other carburetors can I use in its place and do I need to switch the intake manifold.
thanks,
Barry
barry is offline   Reply With Quote
Old 07-27-2011, 06:23 PM   #2
f1builder
Default Re: alternate 32 V8 carburetor
is your carb a one barrel? i am not familiar with the detroit lubricator carb. i would think a stromberg 48 or 97 r even 81 would run on it or the 94 holley carbs. more info please.
f1builder is offline   Reply With Quote
Old 07-27-2011, 06:28 PM   #3
barry
the detroit carb is a single barrel downdraft.
Old 07-27-2011, 06:40 PM   #4
Terry,OH
Terry,OH's Avatar
There is an adapter from the single barrel DL to the Stromberg 2-barrel base so any of the Strombergs could be used. I believe Marvel also made a replacement for the DL without the adapter.
Old 07-27-2011, 06:46 PM   #5
DavidG
DavidG's Avatar
Switching to any two barrel carburetor will entail a change to a '34 or later intake manifold, which in turn will entail a change in generators, fuel pumps and perhaps the fan. There were some adapters made at one time to mount a two-barrel carburetor on a '32 or '33 manifold, but that set up looks pretty inefficient, in my opinion.
Old 07-27-2011, 08:40 PM   #6
f1builder
this adapter is nice, it is cast and the only marking on it is 740. i have been trying to find another just like it for years but no luck. it would work for you if you wanted to run a 2bbl stromberg or holley and if you are interested you can PM me your email for info.
george
Old 07-27-2011, 09:58 PM   #7
FL&WVMIKE
FL&WVMIKE's Avatar
F1builder ............
Your adapter is upside down.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 07-28-2011, 01:10 AM   #8
f1builder
MIKE
funny....but thats not the only thing that is upside down.
Old 07-28-2011, 03:17 AM   #9
Ian NZ
Ian NZ's Avatar
I run Detriot lube carburettor on my 32 and I have had no problems at all.
A carburettor from the 6 cylinder side valve ford developed in the 40's will fit and works well but you have to alter the linkages and the aircleaner, also over here in N.Z. there is one model of Holden ( General Motors product) carburettor fits and works O/K.
Ian NZ is offline   Reply With Quote
