Closed Thread
Old 07-25-2011, 04:06 PM   #1
38 Conv
38 Conv's Avatar
Default Differance 41 Ford 1/2 ton vs 3/4-1 ton
Where is the differance between Ford 1/2 ton VS 3/4-1 ton--Front sheet metal--frame-- suspension--cab--etc- Thanks
38 Conv is offline
Old 07-25-2011, 06:31 PM   #2
svm99
Default Re: Differance 41 Ford 1/2 ton vs 3/4-1 ton
Everything you listed is different except the cab which has a seat tank instead of a seat riser. The axles are larger on both with the 1 ton using larger brakes. Find a copy of James K Wagner's book on Ford trucks and you'll see the differences. The front end sheetmetal is the same as 2 ton truck.
Good luck,
Paul J.
svm99 is offline
Closed Thread
