Old 07-01-2011, 03:27 PM   #1
Jerry Huntngton Beach
Default Locating a VIN number
Where should I start looking for a VIN number on my '29 Open Cab Pickup? ? ? Engine has a June '29 number.
Thanks in advance, Jerry
Jerry Huntngton Beach is offline   Reply With Quote
Old 07-01-2011, 03:37 PM   #2
Chris Haynes
Chris Haynes's Avatar
Default Re: Locating a VIN number
It is on the top of the drivers side frame rail. Under the body and splash apron next to the body mount that is rivited to the frame.
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 07-01-2011, 03:38 PM   #3
31Tudor
31Tudor's Avatar
The engine number was originally the VIN number. When the engine was installed the frame was stamped with the engine number on the top rail of the drivers side, about across from the battery area. the only way to see this number is with the body off, and many times there is to much rust/ pits to clearly see the number.
31Tudor is offline   Reply With Quote
Old 07-01-2011, 06:41 PM   #4
gunmetal blue
gunmetal blue's Avatar
Send a message via Yahoo to gunmetal blue
This is on my 29 AA CCPU see pics. This is on drivers side infront of firewall.
gunmetal blue is offline   Reply With Quote
Old 07-04-2011, 07:06 AM   #5
rat_rodder
if you have a frame with unidentified numbers what are options to use the frame etc
rat_rodder is offline   Reply With Quote
Old 07-04-2011, 07:33 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
Sometimes the unidentifiable numbers need to be restamped into numbers that you can read, later in "A" production the shape of some # changed, the service bulletins has a picture of the numbers and when they changed.
When a new engine block was installed by a dealer it was expected that the dealer stamp the cars original number on the new engine block.
Old 07-04-2011, 11:02 AM   #7
Chris Haynes
You can buy reproduction Ford stamps on eBay.
1921 Runabout
1930 Tudor
Early 1930 AA
