#1 |
I am not sure what is supposed to hold down the metal plate that goes on the floor board around the shifter and emergency brake. Any help or maybe a photo or two would be greatly appreciated!!
Thanks and have a great and safe weekend. Bob |
#2 |
i believe it takes like 3-4 deck screws . you can screw it to the floor ..........
V4f |
#3 |
It is not screwed down. There are three tabs that are riveted to the upper (1) and lower (2) floorboards. These tabs rotate into position to hold the plate down and also allow for easy removal.
#4 |
If you have a Bratton's catalog look on page 111.
Larry Seemann |
#5 |
Registered User
there are three tabs that swivel to hold the plate in place
they are riveted to the floor board the two on the bottom pictured are just screwed in ,the original on the top is correct and riveted tom |
#6 |
Fred Kroon 1929 Std Coupe 1929 Huckster |
#7 |
Thanks all!
#8 |
Fred: "Go slowly for a more harmonious outcome." —Sioux Indian saying.
#9 |
Guess the old stubborn dutchman has to go full speed ahead when into something and doesn't look for the harmonious outcome-at least that is what my wife tells me!
