Old 06-23-2011, 08:42 AM   #1
Ed in Maine
Default 1932 Coupe Transmission
The rebuilt transmission in my 1932 Coupe shifts nicely when driving the car. However, sometimes it is difficult to shift out of gear into neutral when the car is on a slight hill and I have come to a stop. I have to gently let out the clutch and "lurch" the car slightly to unload the drive train to get the transmission into neutral. I have taken the top off of the transmission and with the car sitting in the garage, you can slide each gear very easily with your fingers. It is a nuisance. What is causing this problem? Thanks, Ed
Ed in Maine is offline   Reply With Quote
Old 06-23-2011, 01:07 PM   #2
Mart
Mart's Avatar
Default Re: 1932 Coupe Transmission
Clutch drag???
Old 06-23-2011, 09:13 PM   #3
svm99
Is this a '32 type trans with straight cut teeth or a later with a helical tooth cut? The straight could be harder to shift when "loaded" by the drive line.
Paul J.
svm99 is offline   Reply With Quote
Old 06-24-2011, 06:44 AM   #4
1931 flamingo
1931 flamingo's Avatar
What weight oil/lube are you running in the tranny??
Paul in CT
Old 06-28-2011, 10:56 AM   #5
Ed in Maine
I am using heavy gear oil, 600W. The gears are helical. What transmission oil would you recommend? Ed
Old 06-28-2011, 11:07 AM   #6
David J
David J's Avatar
140 OR 85-140 . Helical gears mean 36-up gears . I use 140 in steering,tranny,u-joint & rear end . The tar you are currently using for lube is probably your trouble . David J
David J is offline   Reply With Quote
Old 06-28-2011, 12:53 PM   #7
Charlie ny
Ed,
What Dave says. Any good grade 85-140 weight will
probably remedy the jam.
Charlie ny
Charlie ny is offline   Reply With Quote
Old 06-29-2011, 11:12 AM   #8
Ed in Maine
Thank you for the recommendation on using the lighter oil. I will give it a try. Ed
