Old 06-07-2011, 02:13 PM   #1
Bill O'Brien
Question Tudor - Floorboard Seal / Webbing
On the Snyders website they list two seperate webbing kits for the floorboards.
http://www.snydersantiqueauto.com/3348
In the description it says "If you have a Tudor Sedan, you will also need kitA-35130-S2 to do the center and rear boards."
Do I need to buy both for my Tudor or is that a bit of a typo and I only need the 2nd one for my car?
Bill O'Brien is offline   Reply With Quote
Old 06-07-2011, 02:19 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Tudor - Floorboard Seal / Webbing
From the way it is written, you need to buy BOTH kits. The price looks like it also, since the first kit does the front floorboard, and the second kit does the middle AND rear boards.
Old 06-07-2011, 03:24 PM   #3
Dave27
Do most people stain their floorboards or paint them.I thought I read somewhere black stain.Thanks....Dave
Dave27 is offline   Reply With Quote
Old 06-07-2011, 03:32 PM   #4
31Tudor
31Tudor's Avatar
It is more the finish of a light coat of flat black paint
31Tudor is offline   Reply With Quote
Old 06-07-2011, 03:42 PM   #5
31Tudor
31Tudor's Avatar
Peter uses a Minwax product, which does show the grain. He has used it on his fine point cars.
Old 06-07-2011, 05:51 PM   #6
Tom Wesenberg
I'm going to paint the repro floorboards I've made, so they look just like these original painted early 29 Tudor boards.
Old 06-07-2011, 06:48 PM   #7
Rem/Mo
Rem/Mo's Avatar
I didn't think a tudor had a rear floor board. Only a front and center.
Rem/Mo is offline   Reply With Quote
Old 06-07-2011, 06:54 PM   #8
Tom Wesenberg
The center board is under the front bucket seats, and the rear seat passengers put their feet on the rear board.
Old 06-08-2011, 12:37 PM   #9
Dave27
Yah a minwax would probly be a good way to go.The only thing I worry about with black paint is that it may flake off and look bad where as a Black stain or something dark that soaks into the would with a sealer on it would last for a very long time.But if black paint is origonal not sure what to do.Hmmm have to think on it.
Old 06-08-2011, 01:59 PM   #10
Clydes 31 P/U
My Dad used black rustoleum thinned way down with mineral spirits.
Clydes 31 P/U is offline   Reply With Quote
Old 06-08-2011, 02:43 PM   #11
Stinch
Stinch's Avatar
I use Woodlife Creocoat on all my wood and it's water cleanup: http://www.wolman.com/product_detail.asp?ProductID=15
E30 68-B Cabriolet
Stinch is offline   Reply With Quote
Old 07-25-2011, 11:08 AM   #12
Bill O'Brien
On my floorboard only 3 sides have webbing on them. The section at the top of the floorboard has none. Is this correct? On the corners, do you just fold it over and nail it down ?? Thanks!
Old 07-25-2011, 11:25 AM   #13
V4F
V4F's Avatar
i use a good water resistent stain ................
V4f
V4F is offline   Reply With Quote
Old 07-25-2011, 08:16 PM   #14
Bruce,Upstate NY
Spray the boards with PPG DP90LF like you used on the bare steel. It will never peal off.
Bruce,Upstate NY is offline   Reply With Quote
Old 07-25-2011, 10:07 PM   #15
Tom Wesenberg
Yes, look at my original boards in post 6. It shows the corners folded to form a 45* line.
