Old 06-07-2011, 12:49 PM   #1
Junior964
Default V-Belt help for my '46 Ford Truck
Hello All,
I was wondering if someone had the same problem I am having with replacing the belts on their 1946 Ford Pick-up. I have the flat 6 (G) which has the two v-belts. in the green parts book it says the part numbers are:
2GA-8620-A (Gen)
2GT-8620-A (Fan)
I have tried everywhere to find replacement belts, but the ones that I have found are not tight enough, and the fan belt keeps chirping. I called Mac's and they told me to try a tractor supply place they sould have the size's I need. Does anyone know the correct size of belts I will need. I believe the gen. belt is 34 1/8" belt, but I am not sure. I have no idea what the correct size of belt I need for the fan belt.
Any help I would be very grateful!
Regards,
Jeff
Junior964 is offline   Reply With Quote
Old 06-07-2011, 01:05 PM   #2
Bruce Lancaster
Default Re: V-Belt help for my '46 Ford Truck
2GA-8620-A is 22.49, 2GT-8620-A is 31.97, according to fanbelt chart in Service Bulletins. I think that would make designations above backwards, judging from pictures in G overhaul book.
Bruce Lancaster is offline   Reply With Quote
Old 06-07-2011, 01:37 PM   #3
wga
wga's Avatar
Got mine from a Gates industrial distributor.
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 06-07-2011, 01:54 PM   #4
Junior964
You would happen to know the art numbers for the belts you purchased from Gates industrial distributor? Thanks!
Old 06-07-2011, 02:04 PM   #5
Clem Clement
Clem Clement's Avatar
Lawn mover shops have odd sizes. Some are uuuuugly green, but hey...
Clem Clement is offline   Reply With Quote
Old 06-07-2011, 02:07 PM   #6
Henry/Kokomo
Henry/Kokomo's Avatar
My local NAPA store, which also has a lot of tractor and agricultural machinery parts, was able to provide the right section belt in numerous lengths. You might try there.
Henry/Kokomo is offline   Reply With Quote
Old 06-07-2011, 02:08 PM   #7
Junior964
at this point they could be hot pink! I just want the chirping to go away! LOL
Old 06-07-2011, 02:12 PM   #8
Junior964
I contacted a Gates industrial distributor and their sizes are not jiving with the sizes above. I am not sure what to do? The smallest "B" belt which is 31" x 21/32". Which I can use for the gen belt, but I cannot find the correct size for the fan belt.
Old 06-07-2011, 11:09 PM   #9
wga
wga's Avatar
Jr - I sent you an email with the Gates belts I had used. Cog style. Let me know if you did not receive.
Old 06-08-2011, 12:29 PM   #10
Bob C
Jeff, The green book shows 2GT-8620-A for the generator and 2GT-8577-A
for the water pump. 2GT-8620-A crosses to NAPA 25-28346 or Gates TR28346.
Can't find a cross for 2GT-8577-A.
Bob
Bob C is online now   Reply With Quote
Old 06-22-2011, 11:45 AM   #11
Junior964
thanks Bob and wga for the info!
Old 06-22-2011, 11:45 AM   #12
Junior964
sorry and everyone too!
Old 06-22-2011, 04:06 PM   #13
gearhead1952
gearhead1952's Avatar
As I have found the belt lengths, that are sold at auto parts places, do not increase or decrease in small amounts. What I have done is to go to the next size down in belt width then see what lengths are available. That may allow you to get a belt that is maybe a half inch shorter than the one you have now. I think I went to a 11/16 width belt when I added an alternator and needed a slightly longer belt.
gearhead1952 is offline   Reply With Quote
Old 06-22-2011, 05:54 PM   #14
joe plumber
As mentioned ,try Napa.
joe plumber is offline   Reply With Quote
Old 06-22-2011, 07:41 PM   #15
Karl Wolf
Karl Wolf's Avatar
Auto parts stores used to ALL have size charts, I'm used to Gates- they had very good ones... Recent experience, Kragen was able to go by size... The sales guy you find may not know what a size chart is... Karl
Karl Wolf is offline   Reply With Quote
Old 06-23-2011, 07:59 PM   #16
darrenct83
I had the same problem for a long time on my 46 1-1/2 ton. Dual matched belts. I couldn't get matches anywhere, and I tried the tractor stores. I finally found a guy in New Jersey who specialized in parts for 1 ton and over trucks. I'm sure the belts are the same though.
The business was "Half Ton Fun". They should have what you're looking for. (732) 928-9421
Remember when you are making your belt adjustment that the generator moves on two axis. Up and down to get the pulleys the right distance apart to take up both belts slack as well as a pivot outward for applying tension.
darrenct83 is offline   Reply With Quote
Old 06-23-2011, 08:20 PM   #17
tdlmomowers
tdlmomowers's Avatar
Go to NAPA. The belt book has all the belts listed by Top Width and then by Length. Ask the counterman to interchange the Ford numbers and then see what they translate to. The belt book has an interchange or the computor also has an interchange. I just interchanged 2 belts for a tractor I was working on, and they fit fine.
tdlmomowers is offline   Reply With Quote
Old 06-23-2011, 11:03 PM   #18
47COE
47COE's Avatar
V Belt Supply http://www.vbeltsupply.com/ has a large selection at very good prices.
The people I have talked to have been very helpful.
Give them a call and tell them what you are trying to do. They will probably come up with the proper belts.
That said, when one of the fan belts broke on my COE, I got a replacement at my local NAPA store. Just took the broken one in.
Tom
47COE is offline   Reply With Quote
Old 05-08-2013, 12:16 PM   #19
Chris
Chris's Avatar
Does anyone have a Gates or Napa number for the smaller (fan) belt? I'm having a heck of a time finding these belts!!!
Thee Inland Emperors
Chris is offline   Reply With Quote
Old 05-08-2013, 05:50 PM   #20
1931 flamingo
1931 flamingo's Avatar
I don't (can't remember) know the fellows name/place in texas (Stacey?) for old ford parts. maybe he has and someone will chime in with name/location.
Paul in CT
