Old 05-31-2011, 12:39 PM   #1
Coupe35
Default Who has the best firewall insulator 35/36
For 35/36 car anyone know who has the best fitting firewall insulator. I purchased one for a 34 2 years ago and the holes were way off. Do not want to make that same mistake again with a 35/36.
Coupe35 is offline   Reply With Quote
Old 05-31-2011, 01:41 PM   #2
Brian
Brian's Avatar
Default Re: Who has the best firewall insulator 35/36
I asked this same question some weeks back, it appears there is two types available, fibreglass and ABS plastic. I was advised the ABS is the better of the two. I have ordered and still awaiting delivery so have no first hand knowledge as to fit etc. One would think that for the price of such an item that it should fit correctly! Which one did you purchase for your 34? Brian
Brian is offline   Reply With Quote
Old 05-31-2011, 02:48 PM   #3
Coupe35
I do not remembr what the insulator was made of. Who did you purchase yours from and price, thanks
Old 05-31-2011, 03:01 PM   #4
deuce lover
deuce lover's Avatar
I used the ABS that I bought from Drake in a 35 sedan I had.I believe Carpenter makes it(not Drake).The only hole that was a little off was the one for the wire loom (dash to engine).I found the ABS one to be to shiney so I wiped it down with lacquer thinner to dull it.The grommet did not fit as it should have but I made it work.I have the Fiberglass one in my 36 coupe which was in it when I bought the car and it appears to fit fine.
deuce lover is offline   Reply With Quote
Old 05-31-2011, 10:12 PM   #5
Trelpdx
Trelpdx's Avatar
I just put in an ABS type in my 35 coupe and it fit pretty good. It is a bit too shinny though. May use the lacquer thinner trick to dull it. I bought it from Mac's.
Trelpdx is offline   Reply With Quote
