05-26-2011, 05:33 PM | #1 |
Restoration Qs...E.A. horns
With the 2011 revision, page 19-4, there are 2 styles of stampings for E.A.,
on the motor base/projector. 1. Which came first? 2. Is there a date/time line for the change? Thank you, Dudley |
05-26-2011, 07:06 PM | #2 |
Registered User
Re: Restoration Qs...E.A. horns
Dudley
I cant help on the time line ,but here are a few variations on the EA horn I'm posting it just for show and tell Nothing documented Maybe it will stir up a little help some EA horns have the EA stamp on just the bell ,and some have it on the bell and the motor base same size the early ones have a different horn cover and zinc tag there were a lot of these used in Canada,I believe for all years tom |
05-26-2011, 07:13 PM | #3 |
Mot, not trying to bust you up, so correct me if I am wrong on any of this, but I do not beleive the Model "S" is for a Model A. I have always been told the "F" in "FM" is for Ford. I had a very nice model "JM" afew years ago, it was about 1/4" shorter in the bell than the "FM", but I never did figure out car it actually came off of. Rod
05-26-2011, 07:27 PM | #4 |
Tom,
If I'm looking at that correctly , photo #4, the EA is on the TOP? |
05-26-2011, 09:51 PM | #5 |
Registered User
Im not trying to waylay Dudleys thread
Just trying to figure out what the different Stamps he asked about in the new JS I just have a few EA horns and have never seen anything on them so I posted what I have in the hopes others will maybe answer his question I have no Idea what the horn is from It looks like model A I started to restore it decades ago ,and just have it in good shape It is defintely different than all the other horns I've seen The wire has a dab of solder from the field to the brushes,and is original the adjusting nut at the top is very different ,and the hole spacing is very different than later horns Lets see what other stampings are out there the tag is on the bottom of the cover and the EA is at the bottom also Ive shown you mine now lets see yours |
05-27-2011, 01:44 AM | #6 |
To try & answer d.j.'s question, I believe the EA. cover with the protruding centre preceeded the flat centre cover. EA Laboratories 'FM' horns are the most common type seen on Canadian A's here in NZ . My ''29 still has its original EA, flat centre cover, but Ive seen the other type on original '28's. I regret selling a nice rare GIM horn years ago. |
05-27-2011, 10:51 AM | #7 |
Tom,
Your not waylaying anything. This was a question to this forum,... for understanding. Your horn in post #5, is the early style, from the beginning of production till May 1928? I've never seen one with the motor cover off, I don't know. Just reread your post, this is the same horn with the " MILEAWAY " tag on it? Interesting. |
05-27-2011, 10:57 AM | #8 |
Just to share the pic and possibly add to the conversation here is a pic of the back cover of the FM horn I had. I looked but did not find a pic in my files of the JM. Not suprising as I purge my pic's routinely. Rod
05-27-2011, 12:00 PM | #9 |
Here's one I found.
Beauty's in the eye of the beerholder? |
05-27-2011, 01:26 PM | #10 |
The ? was only on the shape of the "E-A" stamped on the horns, I think ??.. I would think that they would put them in order in the standards.. "Early to Late" ??.. Let me check on mine as I have several..
05-27-2011, 03:14 PM | #11 |
Craig,
The motor base is stamped EA, the adjuster on the bridge is different,( like a Sparton) not what I have. |
05-04-2018, 03:16 PM | #12 |
FYI - I just posted one of these horns for sale in the classifieds on this site.... Check out the post here: https://www.fordbarn.com/forum/showt...11#post1625411
See and hear a video of this horn working by clicking on the following link: https://youtu.be/cLctc9oVj-Y
-------------- Drive it like you know how to fix it! DMAFC / OILERS CC-MC Last edited by Jason in TX; 05-07-2018 at 11:18 AM. |
05-04-2018, 04:43 PM | #13 |
Imo, the sans-serif serif and serif font were used interchangeably.
05-05-2018, 01:11 PM | #14 |
My early 1930 coupe has original horn, EA with serifs. (EA horn was used only 28-29). Indented cover, Sparton hole spacing, no ID markings - cover may have been replaced.
Update: determined it's the wrong cover. nvm. Last edited by Badpuppy; 07-03-2018 at 10:05 AM. |
