View Poll Results: What type of carb are you running?
Zenith 1 43 31.16%
Zenith 2 33 23.91%
Model B (32 -etc..) 12 8.70%
Tilly 23 16.67%
Marvel or other updraft 9 6.52%
Stromberg or other downdraft 18 13.04%
Voters: 138. You may not vote on this poll
Old 06-02-2010, 06:02 AM   #1
Kevin - Illinois
Kevin - Illinois's Avatar
Question Type of carb you are using...POLL
What type of carb are you running with? Why do you prefer the carb you are using?
Sorry I left out Zenith 3 and side bowl...I'm trying to add them but I doubt I can.
Kevin - Illinois is offline   Reply With Quote
Old 06-02-2010, 07:53 AM   #2
Brian SATX
Brian SATX's Avatar
Default Re: Type of carb you are using...POLL
PM sent
Brian SATX
Brian SATX is offline   Reply With Quote
Old 06-02-2010, 08:15 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
In my opinion the original Zenith is best because of the adjustability --it can be adjusted from too lean, to too rich while driving, ---and the ease of cleaning ---only 1 bolt holding it together,and it doesn't even have to be totally removed to clean the bowl.
Old 06-02-2010, 08:16 AM   #4
Chris in CT
Hi Kevin, As with so many polls, the available choices do not necessarily cover the spectrum of choices avalalable, or the specificity of solutions the hobby has come to. i.e., There are many A'ers who are using one of the NEW Zenith (see Zenith Fuel Systems) updraft carbs on their cars. "Marvel or other updraft" does not cover the implications of this. Also, there are some of us who are beginning to experiment with throttle-body fuel injection (just for laughs, I assure you), but there may be more of this as time goes by, This also has its own implications. As for me, I am running an original Zenith, a NEW Zenith, and installing TBI from a 1990 Pontiac "Iron Duke" 4.
Just to find out what the differences are! ;>)
Chris in CT is offline   Reply With Quote
Old 06-02-2010, 08:23 AM   #5
pat in Santa Cruz
pat in Santa Cruz's Avatar
problem with only allowing me one answer is I have more than one Model A. They each have a different carburetor. I hear the average owner has 3 cars. So how accurate will this poll be?
pat in Santa Cruz is offline   Reply With Quote
Old 06-02-2010, 09:21 AM   #6
T.W.Dustin
T.W.Dustin's Avatar
I am running a Stromberg 97 downdraft (English) mounted on a Scalded Dog intake.
T.W.Dustin is offline   Reply With Quote
Old 06-02-2010, 09:32 AM   #7
Tacoma Bob
Tacoma Bob's Avatar
Have used both. The Till "seems" a bit peppier but is prone to warping. I wrestled with the Zenith until I finally achieved success in how it performs and that is what Ford designed for the car. To date a shy 20 mpg on the highway.
Tacoma Bob is offline   Reply With Quote
Old 06-02-2010, 10:06 AM   #8
Rowdy
Using a Zenith 1 for now, but planning on running a Stromberg 48 later on. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 06-02-2010, 10:42 AM   #9
allen
allen's Avatar
Send a message via ICQ to allen
side bowl zenith and zenith 2 , have run a tilly and it ran great
allen is offline   Reply With Quote
Old 06-02-2010, 10:52 AM   #10
Ron in Quincy
Ron in Quincy's Avatar
There are so many variations of the Zenith-1 and Zenith-2, such as removable or cast needle seat, 3 types of secondary wells, variations in jet sizes, etc., that your poll doesn't cover. You also have the Zenith and Holley Double Venturi Carburetors you didn't include; Zenith-1 and Zenith-2 didn't come in too being until approx. Jan. 1929 when the numbers were added to identify the manifacture of the carburetor.
Ron in Quincy is offline   Reply With Quote
Old 06-02-2010, 10:52 AM   #11
Bob Johnson
Bob Johnson's Avatar
I did a survey about modifications and carburetor choice was one of the questions. It is not exactly what you are looking for but it may help. See Survey link below.
Bob
Survey
Bob Johnson is offline   Reply With Quote
Old 06-02-2010, 11:04 AM   #12
John Butts in CT
John Butts in CT's Avatar
Late '31 side bowl Zenith. One on the car; two restored and on the shelf "just in case."
John Butts in CT is offline   Reply With Quote
Old 06-02-2010, 11:18 AM   #13
Patrick L.
Patrick L.'s Avatar
Using a Tillotson and it runs fine so I haven't bothered to change it over the past 34 years.. Maybe some day when I feel like digging out a couple Zeniths from the junk box I'll see if I can't make a good one from the pile of parts..
Old 06-02-2010, 11:26 AM   #14
LeroyM
LeroyM's Avatar
Stromberg 97. 0.43 main jets and 0.67 power valve. Runs good with a Snyder's high compression head and lightened flywheel.
LeroyM is offline   Reply With Quote
Old 06-02-2010, 11:28 AM   #15
MikeK
MikeK's Avatar
For a serious tire kickin', hood open event only the correct Zenith will do. The rest of the time, when I want cold starts on the first crank, no driving lag or flat spots, and better than 20 mpg, I use a slightly tweaked Marvel. A little less top end, but that's the tradeoff. Unlike the Zenith, the Marvel is also insensitive to hard braking or turns. But nothing beats the look of the correct Zenith.
MikeK is offline   Reply With Quote
Old 06-02-2010, 11:28 AM   #16
Tom from Drippin'
Tom from Drippin''s Avatar
Yup! 2 B's and a Tilly
The pursuit of excellence is healthy and rewarding.
The pursuit of perfection is frustrating, neurotic and a terrible waste of time.
Tom from Drippin' is offline   Reply With Quote
Old 06-02-2010, 01:17 PM   #17
msmaron
msmaron's Avatar
#3 and side bowl
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 06-02-2010, 01:38 PM   #18
stevematta
stevematta's Avatar
I have the opposite experience...the Tillotson carb I'm using now is a replacement while I rebuild the Zenith. I much prefer the Zenith and I'm anxious to get it back in my truck.
I've had trouble fine tuning this Tilly to start and run smoothly. Seems it's either racing or it wants to die on me...can't find the happy median.
Mike at Mike's A-Ford-able says they are about to carry a Zenith alternative...I'm anxious to give that a try.
stevematta is offline   Reply With Quote
Old 06-02-2010, 01:45 PM   #19
Art Bjornestad
Art Bjornestad's Avatar
Model B with a K&N filter
Art Bjornestad is offline   Reply With Quote
Old 06-02-2010, 03:08 PM   #20
Aerocraft
Aerocraft's Avatar
Four cars on the road and four Zenith's. Gar Williams
Aerocraft is offline   Reply With Quote
