Old 05-17-2026, 11:24 PM   #1
JD4430
Default Can I put on new head nuts without creating future head gasket leaks??
I recently repainted my motor and now I would like to replace the engine head nuts with a new set of cadmium plated nuts I just bought. Currently I don't have any head gasket leakage and I don't want to create any future gasket leaks by disturbing the head nuts that are in place now. Is there a proper way to do this or am I just asking for trouble?
JD4430 is offline   Reply With Quote
Old 05-18-2026, 03:27 AM   #2
johnbuckley
johnbuckley's Avatar
Default Re: Can I put on new head nuts without creating future head gasket leaks??
Hmm, you're possibly OK to go ahead...but even one nut at a time it's a gamble and I'm a great believer in "If it ain't broke don't fix it." .
johnbuckley is offline   Reply With Quote
Old 05-18-2026, 05:09 AM   #3
BButturff
BButturff's Avatar
For me, it would depend on what I knew about the type of head gasket that was last used, how it was installed and how true the block and head surfaces are. If I didn't know the history I would lower the coolant level, go 1 nut at a time and have another head gasket on hand (Best 509G) and some copper coat spray so I'm able to replace it. Otherwise, I wouldn't take the risk either. I have had a head gasket that I didn't think was leaking but when the head was removed there was evidence of an internal leak. You might be opening up a can of worms and have no plans to go fishing.
_______________________
The other Bruce in Minnesota
1931 Model A Closed Cab (Budd) Pickup "Aurora"
Model A Ford Club of America
Lady Slipper A's
"You can't go back and change the beginning,
but you can start where you are and change
the ending." - C.S. Lewis
BButturff is offline   Reply With Quote
Old 05-18-2026, 08:48 AM   #4
katy
katy's Avatar
Why not get a set of the chrome plated or stainless steel "acorn" nut covers?
Old 05-18-2026, 09:25 AM   #5
P.S.
I was just going to suggest the same thing.
2024-2026 MAFCA Technical Director
P.S. is offline   Reply With Quote
Old 05-18-2026, 12:47 PM   #6
MJRodge
One at a time shouldn’t cause any problems. Do it in the torque order. Do it when engine is cold.
-Mike
MJRodge is offline   Reply With Quote
Old 05-18-2026, 04:55 PM   #7
mcgarrett
I would at least drain the cooling system completely before proceeding.
mcgarrett is offline   Reply With Quote
Old 05-18-2026, 05:03 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
I third that motion...
Old 05-18-2026, 07:05 PM   #9
WHN
-Mike
I have done this way without any problems.
Enjoy
WHN is offline   Reply With Quote
Old 05-18-2026, 07:27 PM   #10
Synchro909
Synchro909's Avatar
Before the return drive from a National Model A rally a few years ago, one guy checked his head nut tension and found two studs were pulling out of the block. I told him to stop immediately and drive home. Fix it then. If he could DRIVE 1,150 miles home with TWO loose head nuts, I see no reason why you can't change them one at a time as has been suggested above. Once you had done that, I would go through the heat and cool tensioning process again at least once.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 05-18-2026, 07:51 PM   #11
JD4430
Thankyou to everyone who responded to my question. I decided not to take any chances and so I am going to get the chrome acorn head nut covers. Thankyou all again. It is appreciated.
Old 05-19-2026, 07:50 PM   #12
old ugly
old ugly's Avatar
do one at a time and don't drain the coolant. that way the head stays torqued.
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 05-20-2026, 08:36 AM   #13
Bob Bidonde
Bob Bidonde's Avatar
Here is my recommendation:
*drain at least one gallon of coolant out of the engine, so the coolant level in the engine is below the cylinder head;
*Loosen the cylinder head nuts in the same sequence used to torque them;
*Replace all of the nuts;
*Torque the nuts in the sequence shown in the chart;
*Replenish the coolant in the engine.
I also recommend you modify the ignition cable clamp before replenishing the coolant.
File Type: jpg Cylinder Head Tightening Chart 84kb.jpg (20.6 KB, 12 views)
File Type: jpg Popout Cable Clamp Modification 228kb.jpg (73.9 KB, 18 views)
Bob Bidonde
Old 05-20-2026, 08:42 AM   #14
Bob Bidonde
Bob Bidonde
Last edited by Bob Bidonde; 05-20-2026 at 08:44 AM. Reason: Duplicate post. Please delete it.
