Old 01-08-2026, 06:27 PM   #1
Model51
Model51's Avatar
Default Water pump temperature bulb sealant
Is there any sealant needed for the threads of the nut that holds the temperature sensor in the water pump? The nut seems like straight threads and not pipe threads and there's a lip on the top of the sensor that the nut appears to press against. I'm assuming the sensor and nut don't require any sealant, but I'd rather do it right the first time. The engine is for a stock 1935 Ford and I've attached an image of the sensor and nut only part way installed in the water pump.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 01-09-2026, 01:31 AM   #2
Ernstudet22
Default Re: Water pump temperature bulb sealant
Since the wire goes through the nut, the probe has to seal on the taper. Make sure the seat is clean and smooth.
Ernstudet22 is offline   Reply With Quote
Old 01-09-2026, 03:24 AM   #3
Brian
Brian's Avatar
i always use a generous amount of anti seize compound on the seat of the bulb and the nut, and just 'nip' up the nut sufficient to stop coolant from weeping out. Next time you got to remove the sender unit, you'll be glad you did it that way. So many of the capillary tubes have been wrecked over the years because people have just assembled dry and really cranked down the nut.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 01-09-2026, 11:23 AM   #4
petehoovie
petehoovie's Avatar
Old 01-09-2026, 11:38 AM   #5
Kube
Super Moderator
Kube's Avatar
You are 100% spot on with your advice!
Old 01-09-2026, 04:22 PM   #6
Model51
Model51's Avatar
Thanks for the advise and explanation. I'll definitely put some anti-seize compound between the nut and the sender.
Old 01-09-2026, 06:56 PM   #7
Brian
Brian's Avatar
And just nip up the nut sufficient to prevent weeping at the nut; don't go gorilla!!
