Old 12-15-2025, 02:18 PM   #1
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Dynamat Sound Deadening alternatives??
Often times we get requests to install a sound deadening material (Dynamat) and foil insulation behind the upholstery to help with combatting noise and heat. The costs to install Dynamat is beyond expensive these days. Can anyone recommend a product they have used that they feel is equal to or better than the 18"x32" sheets that Dynamat sells?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-15-2025, 03:02 PM   #2
Hitman
Default Re: Dynamat Sound Deadening alternatives??
What part is expensive, the materials or labor to install them? The sheets/material cost seems reasonable to me.
Hitman is offline   Reply With Quote
Old 12-15-2025, 03:35 PM   #3
noboD
I insolated my garage with a product just like this. It was a bubble wrap with foil meant to be used in chicken houses where the humidity is high. It was cheap and made in America. Sorry I don't remember a name. Maybe check with a pole barn installer?
noboD is offline   Reply With Quote
Old 12-15-2025, 04:23 PM   #4
Bill's Auto Works
Bill's Auto Works's Avatar
Brent,
I have been using "FatMat" on the last 3 cars I did. I buy it off of ebay & feel it is just as good as Dynamat without paying for the name.
God Bless & Merry Christmas
Bill
https://www.jalopyjournal.com/forum/...closed.614419/
"Jealousy is a Sad Pathetic Character Trait Generally Held By The Lazy, Immoral Dregs of Society"
1955 Chevy Altered W.B. Gasser
1955 Nash Amb. Cust. Lemans
1957 T-Bird
1964 Pontiac Grand Prix 2 DR HT
1966 Pontiac Catalina Conv
1966 AMC Ambassador DPL 2 DR HT
1966 AMC Ambassador Cust 2DR HT
1967 AMC Marlin
1967 Toronado
1973 Chevy Nova Full Chassis Car
1992 Jag XJS Conv
1992 Jag XJS 2 DR Coupe
2007 Cadillac XLR-V Supercharged Roadster
2008 Southern Customs Avalanche
Bill's Auto Works is offline   Reply With Quote
Old 12-15-2025, 04:43 PM   #5
LeonardS
B-Quiet.com
They sell top quality sound deadening and heat reducing materials. Check them out. No, I have no affiliation to them other than I bought both material types to help with noise and heat in the cab of my John Deere mower.
LeonardS is offline   Reply With Quote
Old 12-15-2025, 06:14 PM   #6
corvette8n
corvette8n's Avatar
Originally Posted by Bill's Auto Works View Post
Brent,
Bill
Looks like in comes in a couple of thickness, 50 mil and 80 mil, which do you use.?
Old 12-15-2025, 06:57 PM   #7
32Ford13
I've got this stuff in a few cars including my '31 truck. It is top shelf for sure:
https://www.designengineering.com/
Great for heat and sound.
If you want to call them, ask for Mike, you'll get personal service and a TON of knowledge.
32Ford13 is offline   Reply With Quote
Old 12-15-2025, 07:30 PM   #8
ModelA29
ModelA29's Avatar
My car had that under the floor mat. Useless once all the bubbles popped. Maybe OK if glued into a door.
Try these - you can figure out the sq in cost since they are different sizes.
https://www.homedepot.com/pep/39-4-i...CABEgKFRvD_BwE
https://www.summitracing.com/parts/r...iABEgK6cPD_BwE
ModelA29 is offline   Reply With Quote
Old 12-16-2025, 02:09 AM   #9
Oldbluoval
Oldbluoval's Avatar
What about 3M body Schultz or equivalent? I’ve used it before quick and reasonable.
Downside is if you want it gone. It’s basically a hardening undercoat
Oldbluoval is offline   Reply With Quote
Old 12-16-2025, 07:21 AM   #10
Bill's Auto Works
I use the 50 mil, I figure because I always use Jute/Insulation before the carpet it would be plenty. It makes the interior quieter & more comfortable. I have done 3 cars with it & in the near future will be doing three more.
I have also used it around trans lines, fuel lines & starter harnesses that are close to exhaust manifolds/headers.
God Bless
Bill
1957 T-Bird
1967 AMC Marlin
1967 Toronado
1992 Jag XJS Conv
Old 12-16-2025, 07:31 AM   #11
Wick
Wick's Avatar
I go to lowes and buy the roll of air duct insulation. It's self adhesive with a silver backing.
I've used it on about 10 Model As and my VW DC.
It's ez to work with and it works.
Wick is online now   Reply With Quote
Old 12-16-2025, 10:55 AM   #12
Bob Bidonde
Bob Bidonde's Avatar
Noise & Heat Reduction.pdfThis is the sound damping and thermal insulation I put into my Victoria.
Bob Bidonde
Old 12-16-2025, 10:57 AM   #13
Bob Bidonde
Here is the article I wrote for the above Post 12.
Bob Bidonde
Old 12-16-2025, 12:46 PM   #14
30Tudor
30Tudor's Avatar
Great article Bob.
I have been investigating this for my '30 Tudor.
Courtesy of Google AI, sound deadening (soundproofing) effectiveness is primarily determined by four key factors: mass/density, decoupling, absorption, and sealing air gaps. I googled "What are the factors that affect sound deadening" and the answer seems consistent with my knowledge in this area.
Regarding the mass factor, I have found plenty of cheaper 80mil Butyl sound deadening products on Amazon that are probably good enough for a Model A. The heavier Butyl rubber products would work for the inside of the vehicle doors and panels and other products would probably work well for the floors (waterproof, closed cell foam with heat reflective backing).
Above my muffler I have already installed 1/8" Aluminum sheets underneath the floor boards to reflect that heat.
30Tudor is offline   Reply With Quote
Old 12-16-2025, 03:47 PM   #15
Bruce of MN
Bruce of MN's Avatar
I can't find that type on the Lowe's website. Can you post the SKU number or more info?
Bruce of MN is offline   Reply With Quote
Old 12-16-2025, 04:00 PM   #16
CarlG
CarlG's Avatar
I've used a combination of Dynamat and Roadkill. Roadkill seems to work just as well and is less expensive than Dynamat.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-16-2025, 06:05 PM   #17
Bill's Auto Works
This thread actually reminded me that I needed to reorder some! This is what I use.
https://www.ebay.com/itm/225832559507
Will be doing the 67 Marlin probably next week & then the 67 Toro as time permits.
God Bless
Bill
1957 T-Bird
1967 AMC Marlin
1967 Toronado
1992 Jag XJS Conv
Old 12-16-2025, 10:39 PM   #18
Phil Brown
Phil Brown's Avatar
God Bless
Bill
Thank you for the link 👍
Phil Brown is offline   Reply With Quote
Old 12-17-2025, 10:44 PM   #19
Ayers1
Ayers1's Avatar
You can get rolls of this at Lowe's or Home Depot. I glued it in the side panels of my Tudor without a lot of fuss. I also insulated the interior of a 51 DeSoto with it. Black car with a huge top. It definitely made it cooler inside afterwards!
Steve,
Proud owner of
28 Fordor, been in family since 63
30 Tudor
31 S/W Town Sedan
Skyline Chapter MAFCA, MARC
Ayers1 is offline   Reply With Quote
Old 12-18-2025, 07:05 AM   #20
Wick
Wick's Avatar
Lowe's stk 28929 made by Frost King
Duct insulation $27.00
