Old 12-07-2025, 09:27 AM   #1
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default 1932 Rear End Rebuild
I supposedly have a '32 Rear End assembly coming in after the first of the year. Since we stock all of the Bearings, Gaskets, Seals, Hi-speed R & Pinions, etc., how much of the Model-A hard parts will cross-over for use in the Model-B Rear End?
TIA
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-07-2025, 09:41 AM   #2
alchemy
alchemy's Avatar
Default Re: 1932 Rear End Rebuild
First you need to confirm it’s the B not the late production.
alchemy is offline   Reply With Quote
Old 12-07-2025, 03:34 PM   #3
BRENT in 10-uh-C
Any giveaway if the customer would send me pictures of the outside of the Differential Housing or Axle Housings to find out ahead of time??
BRENT in 10-uh-C
Old 12-07-2025, 04:10 PM   #4
Bob C
The one that is the same as a Model A is round where the torque tube bolts to the center section and the later ones are scalloped.
Old 12-07-2025, 04:55 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
The most common one is the one with the round flange where the torque-tube mates up. You see these the vast majority of the time. Late in 32, they updated the rear to have a pinion support bearing and these later rears have a scalloped flange - like all of the later rears. These late 32 rears share the same parts, axles, bells, etc - as 33 and 34 rears - EXCEPT the rear radius rod mounts are straight and not angled like the 33-34 rears. Hope that helps.
Old 12-07-2025, 05:02 PM   #6
petehoovie
petehoovie's Avatar
Old 12-07-2025, 05:35 PM   #7
BRENT in 10-uh-C
Thank you Gentlemen. If it is the round Torque Tube style, everything else Model-A (-except the Axles) should work??
BRENT in 10-uh-C
Old 12-07-2025, 09:05 PM   #8
Cool Kat with Hot Car
Cool Kat with Hot Car's Avatar
axles are the same, axle housing are not
Cool Kat with Hot Car is offline   Reply With Quote
Old 12-08-2025, 01:15 AM   #9
deuce lover
deuce lover's Avatar
Here is a pic of the 32 rear end.Not the late variety.
deuce lover is offline   Reply With Quote
Old 12-08-2025, 01:47 AM   #10
petehoovie
petehoovie's Avatar
Old 12-08-2025, 12:26 PM   #11
alchemy
alchemy's Avatar
I’m pretty sure the late 32’s also had angled wishbone mounts. I’ve never seen a late one with parallel mounts like the B’s have.
Old 12-08-2025, 01:13 PM   #12
rotorwrench
rotorwrench's Avatar
The first B axle is similar to the A as was mentioned, same axle shafts, same internal bearings, and same R&P. The bells, torque tube, and driveshaft are completely different.
This is a good link for overhaul on the early type B.
https://www.santaanitaas.org/wp-cont...une-2-2019.pdf
The later axles made to work for both the B and the V8 are more like the later banjos so nothing interchanges. The torque tubes and drive shafts are different between B and V8 due to engine length diffrences.
Old 12-08-2025, 04:17 PM   #13
jimTN
Brent, One of the weakest points of the early 32 axle is the driveshaft bearing behind the u joint. I believe the roller bearing and sleave is the same as an A. If the shaft itself is worn, you may have to cut a section from a A shaft and the B shaft to repair it.
jimTN is offline   Reply With Quote
Old 12-09-2025, 08:49 AM   #14
Bored&Stroked
Pinion and Carrier Bearings: If you happen to have original Ford bearings, I'd use them.
I've heard a lot of horror stories about many of the offshore ones. Also, if the original bearings are good, just reuse them.
