Old 11-28-2025, 01:18 PM   #1
Ed Saniewski
Ed Saniewski's Avatar
Default 1933 aluminum heads
This sounds like a stupid question, but can someone tell me what kind of finish did the aluminum heads have from the factory? was it a high gloss , a dull gloss , or a flat finish? Thanks.
Model A Ford Club of New Jersey
http://www.mafcnj.org
Model A Pick Up Owners and Enthusiasts
https://www.fordbarn.com/forum/group.php?groupid=5
Ed Saniewski is offline   Reply With Quote
Old 11-28-2025, 01:29 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: 1933 aluminum heads
They were left in the raw cast aluminum "finish". No buffing / polishing, no coating of any kind.
Old 11-30-2025, 03:37 PM   #3
rockfla
rockfla's Avatar
As they where for 1934, 1935 & 1936
Old 11-30-2025, 03:51 PM   #4
KiWinUS
KiWinUS's Avatar
Kube do you have a go to method to restore to original finish? I have a few different early Ford and aftermarket aluminum heads but as you know after all these years the no longer look new.
I have tried many different methods and know the look I like.
Thanks mate.
Old 11-30-2025, 04:13 PM   #5
Kube
Super Moderator
Kube's Avatar
Thanks mate.
I glass bead them.
Old 11-30-2025, 05:23 PM   #6
petehoovie
petehoovie's Avatar
Old 11-30-2025, 05:38 PM   #7
petehoovie
petehoovie's Avatar
Here are pictures of the Kearney Pattern Works (Ford Authorized) reproduction heads I purchased for my '34...As seen right out of the box...
Old 11-30-2025, 06:25 PM   #8
KiWinUS
KiWinUS's Avatar
Very nice Pete. I too have a set of the Kearney heads I purchased used and have cleaned up very nicely without bead blasting. I have a pressure bead blaster that is totally amazing buy often make it my last resort.
Old 11-30-2025, 08:40 PM   #9
Ed Saniewski
Thanks , I will try bead blasting.
Old 11-30-2025, 10:15 PM   #10
tubman
tubman's Avatar
I don't know if this applies to the Early Ford World or not, but I'll throw it out because in may be applicable. In the anal-retentive world of Corvette restoration, a bead blasted finish is not the same as it came from the factory, and as I understand it, is different enough to be easily detected. In the world of 100 point Corvette restorations, it is common the have the cleaned aluminum surface "re-skinned" to bring it back to it's original appearance. There are companies that provide this service to those who want it "just right". I believe that it also lasts quite a bit longer than a fresh blasted surface.
Old 12-01-2025, 02:22 AM   #11
deuce lover
deuce lover's Avatar
Careful not to bead blast the underside.
Here are pics of the engine I did for my '33 a few yrs ago
deuce lover is offline   Reply With Quote
Old 12-01-2025, 02:38 AM   #12
petehoovie
petehoovie's Avatar
Old 12-01-2025, 09:18 AM   #13
rockfla
rockfla's Avatar
Just for FYI and not that "anyone" asked about my post.....BUT I used Cerakote C Satin Nickle paint. After the heads were machined, I taped up the mating surface, the water pump openings as well as the spark plug threads and "carefully" bead blasted the heads. Once bead blasted, I blew them off really well with air, then wiped them down really well with denatured alcohol and cleaned them really well. THEN sprayed them with Cerakote C along with the intake manifold and the base of the fuel pump/oil fill tube stand. When I ran it on my run stand, I had an issue with the electric fuel and too much pressure and it pumped fuel all over the intake and heads....ALSO brushed the head with a somewhat greasy finger, NOT ONE issue, not one stain, not one mark left by the fuel NO OFFENSE Pete BUT (NOTE the intake staining just below the carburetor in Pete's photo's). I wiped them back down with denatured alcohol and STILL looked as new and as fresh as the day I painted them!!!! The Cerakote C has a "process" (ie temperature, pressure and distance procedure) but beyond that, very very pleased with the results
Old 12-01-2025, 01:40 PM   #14
petehoovie
petehoovie's Avatar
Just for FYI and not that "anyone" asked about my post.....BUT I used Cerakote C Satin Nickle paint. After the heads were machined, I taped up the mating surface, the water pump openings as well as the spark plug threads and "carefully" bead blasted the heads. Once bead blasted, I blew them off really well with air, then wiped them down really well with denatured alcohol and cleaned them really well. THEN sprayed them with Cerakote C along with the intake manifold and the base of the fuel pump/oil fill tube stand. When I ran it on my run stand, I had an issue with the electric fuel and too much pressure and it pumped fuel all over the intake and heads....ALSO brushed the head with a somewhat greasy finger, NOT ONE issue, not one stain, not one mark left by the fuel NO OFFENSE Pete BUT (NOTE the intake just below the carburetor in Pete's photo's). I wiped them back down with denatured alcohol and STILL looked as new and as fresh as the day I painted them!!!! The Cerakote C has a "process" (ie temperature, pressure and distance procedure) but beyond that, very very pleased with the results
Old 12-01-2025, 02:00 PM   #15
Kube
Super Moderator
Kube's Avatar
I have had the best results with GLASS beads.
Old 12-01-2025, 02:39 PM   #16
35fordtn
35fordtn's Avatar
Glass beads gives the most authentic looks if a fine grade. I use Cerakote Glacier silver as it seals the pores to prevent thumb prints, etc.
35fordtn is offline   Reply With Quote
Old 12-01-2025, 04:00 PM   #17
rockfla
rockfla's Avatar
X3 on "fine" glass bead
Old 12-01-2025, 04:18 PM   #18
Karl Wescott
Karl Wescott's Avatar
It is common foundry practice today to sandblast or beadblast castings to remove any residual sand that may have adhered to the casting, so as cast could be sandblasted. there is almost always some residual sand attached to the casting that has to be removed, whether by hand scraping, blasting, or vibratory beads. Bead blasting may well be 100% correct for a 1930's Ford sand cast item.
Foundry technique has become more sophisticated over the years. Most aluminum castings used by GM from the mid 1950's through the 1990's to me appear to have used a permanent steel mold which has a much finer, detailed finish than a sand casting or a sand blasted casting.
Karl Wescott is offline   Reply With Quote
Old 12-01-2025, 05:50 PM   #19
Ed Saniewski
Kube, what Grit do you use? Amazon lists a #13 glass bead that is 220-240 grit. Is that good ? Thanks
Old 12-01-2025, 06:36 PM   #20
john greco
Vapor blasting IMO
john greco is offline   Reply With Quote
