Old 11-15-2025, 06:10 PM   #1
Adam/Mill Valley CA
Adam/Mill Valley CA's Avatar
Default Shock rebuilder
Who is the current "go-to" guy for lever shock rebuilding? I've seen the name Andy Falandes highly recommended several times, is he still actively doing this? One front shock on my '36 pickup is completely shot and has basically no resistance to motion.
Also, is it the shock/lever arm that actually restrains the front suspension at full droop? I never thought about it before, but I notice the one bad shock's lever arm extends down much further than the other side
Adam
1936 pickup, stock, black
1965 Mustang coupe 289/4bbl, black/red
1971 Alfa Romeo GTV 1750 coupe, dark red/tan
1970 911E 2.2 litre dark blue/black
1968 BMW R50/2 US, black (m'cycle)
1967 Triumph TR6R , sea foam/cream (m'cycle)
2022 Royal Enfield Interceptor 650 red (m'cycle)
1974 Honda CB750 red (m'cycle)
2000 Kawasaki W650 blue/silver (m'cycle)
Adam/Mill Valley CA is offline   Reply With Quote
Old 11-15-2025, 11:54 PM   #2
deuce lover
deuce lover's Avatar
Default Re: Shock rebuilder
Yes Andy is still actively doing shocks.
[email protected]
deuce lover is offline   Reply With Quote
Old 11-16-2025, 12:28 AM   #3
john greco
Just finished my 34 front shock , what service , fast turn around and awesome work ! What an asset to the hobby , last time I dealt with apple hydraulics , what a mess that was , sent same shock back 5 times , and it still leaks , never ever again .
john greco is offline   Reply With Quote
Old 11-16-2025, 07:32 AM   #4
corvette8n
corvette8n's Avatar
I had Andy do all 4 of my shocks, nice job, quick turnaround, great communication.
Old 11-16-2025, 07:56 AM   #5
Kube
Super Moderator
Kube's Avatar
Andy is my guy as well. Recently did a set for a '36 of mine.
Apple? Stay far away. How that place remains in business is beyond my imagination.
Old 11-16-2025, 09:36 AM   #6
Adam/Mill Valley CA
Thanks all, I will certainly send the bad shock to Andy Falandes.
Any thoughts on my second question, as to what constrains the front suspension on a '36 (or any similar transverse spring front end) at full droop? If it is, in fact, that shock lever arm/dogbone link, it seems to me that would put a lot of stress on the internals of the shock after years of dropping a wheel into potholes-but I don't see what else limits the movement.
Adam
Old 11-16-2025, 11:49 AM   #7
Kube
Super Moderator
Kube's Avatar
Adam
The spring keeps the suspension within a designed height (+/-) specification. The shock link should NEVER reach its full travel. If it does, something is gonna break. The shock? The link? Something...
Old 11-16-2025, 08:41 PM   #8
Adam/Mill Valley CA
OK that makes sense. I think my issue is that the passenger side of the spring has lost it's arch, allowing the shock on that side to go beyond its limit-that's the shock that has failed. At this point I'm awaiting a new (stock) spring from Eaton spring, and sending the bad shock to Andy Falandes for a rebuild, if possible-if the shock is beyond repair, then he will try to find a good core for me in his stash.
Adam
