Old 11-14-2025, 12:20 PM   #1
ckh
Default Advice needed: 35-36 21 stud block
After a sonic test showing uniform wall thickness, what is the maximum safe
overbore on a 35-36 block?
Thanks,
CKH
ckh is offline   Reply With Quote
Old 11-14-2025, 01:44 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: Advice needed: 35-36 21 stud block
I try to always have .100”. No matter what year block. Sonic checking is just a good guideline. It too can fail you.
Old 11-14-2025, 06:01 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
If it looks like the first picture in the water jacket it can have a hole at .060 like the block in the picture.—- the LB blocks have thin cylinder walls.
The second picture is a block bored to 3-3/8 and the thinnest spot is .220 ( a 59AB block with a long story and one of the cleanest water jacket I have seen)
Old 11-14-2025, 07:15 PM   #4
petehoovie
petehoovie's Avatar
Old 11-14-2025, 09:37 PM   #5
ckh
Thanks for the replies. I bought this block (not an LB) some time ago. It had ben freshly
bored .060 over stock. I haven't had it sonic tested yet. Assuming there is no core shift, is
.060 over stock pushing the limit?
Old 11-18-2025, 11:50 AM   #6
Bored&Stroked
Bored&Stroked's Avatar
You should be fine with a .060 overbore. With that said, always have the block magged and then pressure tested. I've seen a lot of "good blocks" end up with issues after thorough testing.
Old 11-19-2025, 07:58 AM   #7
richard crow
back in the day 060 was the limet after that they would tend to run hot
richard crow is offline   Reply With Quote
Old 11-19-2025, 02:12 PM   #8
Flathead Fever
Flathead Fever's Avatar
.060 should be fine. I had a friend that bored one .100, that was pushing the limit. I'm not sure I would want one bored that mush unless you were just going to race it.
Flathead Fever is offline   Reply With Quote
Old 11-19-2025, 03:10 PM   #9
ckh
Thanks to all for your replies. You have now given me the info I need. I bought this block several years ago and had it magged, head surfaces, pan rails etc. No cracks
anywhere. The next step will be a sonic test which I should be able to have done
locally in Las Vegas where I live. If the sonic test shows no core shift, I should be able
to pressure test it myself as finding anyone in Las Vegas to pressure test any flathead
is a loseing proposition.
Thanks again for all your help.
The Ford Barn come thru again.
CKH
