Old 11-01-2025, 07:27 PM   #1
3W Hank
Default TQ plate FH
About TQ plate on the FH.
I has a Merc 41 block ported back in the days I bought in LA, but it had a crack from exhaust port to the cylinder ( but very nice port work ) and the fellow sold had it for over 30 years and history it was from a racer and brought it back the the machine shop in Burbank area. I guess could been 50’s or 60’s and it’s 1/8” over std.
When I bought it has been sonic tested and it was over 0.25” wall ( no one believe that ) but pressuare test showed a port hole in 1 cylinder so I bought a 3.5” OD sleeve.
Sleeve its now mounted and idea is hone it equal size and order custom pistons from Ross.
That will be a hair over 1/8” over std ( or .125" )
Block had been in hot tank twice and also laser cleaned.
-So the question is before hone, do this block’s like TQ plate or how is bolts effects cylinders ?
I can make a TQ plate cant find blue prints of bolts.
3W Hank is offline   Reply With Quote
Old 11-02-2025, 02:44 PM   #2
Ronnieroadster
Ronnieroadster's Avatar
Default Re: TQ plate FH
Cylinder distortion can be eliminated when A torque plate is used on a Ford flathead block. The bolts holes located along the outer radius of the bores in the 3,5,7and 9 o'clock positions can distort especially when the bore size has been increased to .125 and above. That also includes when a sleeve has been installed.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Ronnieroadster is offline   Reply With Quote
Old 11-02-2025, 03:15 PM   #3
KiWinUS
KiWinUS's Avatar
I’m with Ronnie above on this. I use my torque plate on all 24 stud flatheads I build. I need to get one for my 21 stud builds. Mine is also cut out around valves like head gasket so I can use it to pressure test.
Old 11-02-2025, 04:56 PM   #4
petehoovie
petehoovie's Avatar
Definition of a Torque Plate
A torque plate is a thick metal plate that is bolted to an engine block during the machining process to simulate the stress that the block will experience when the cylinder head is attached. This helps ensure that the cylinder walls are perfectly round and straight, improving engine performance and durability.
A torque plate is a specialized tool used in engine building. It is a flat plate that is bolted to the engine block during the machining process. The purpose of the torque plate is to simulate the forces that the engine head will apply when the engine is fully assembled.
Old 11-02-2025, 05:20 PM   #5
3W Hank
Thanks.
Any information where a blueprint can be found.
I rather dont like to punch via a head and then manually drill, its easy one need several off. I has done it in my past, but then I bought BHJ's.
Best is had the measures and run it in a CNC.
I do has 50 mm aluminium plates.
Old 11-02-2025, 05:38 PM   #6
Bruce of MN
Bruce of MN's Avatar
I don't recognize BHJ, what is that?
Bruce of MN is offline   Reply With Quote
Old 11-02-2025, 07:16 PM   #7
petehoovie
petehoovie's Avatar
BHJ Products manufactures quality, precision tooling and equipment for performance engine builders and machinists.
See > https://honingplates.com/index.php?main_page=contact_us
Old 11-02-2025, 08:54 PM   #8
big deuce
big deuce's Avatar
I made one from an old head that a valve went through the combustion chamber. Made a template/guide from 2" thick hardwood based on a gasket. Holesaw, and patients.
big deuce is online now   Reply With Quote
Old 11-02-2025, 11:03 PM   #9
cas3
Nice job!
cas3 is online now   Reply With Quote
Old 11-02-2025, 11:36 PM   #10
petehoovie
petehoovie's Avatar
Old 11-03-2025, 03:06 PM   #11
rockfla
rockfla's Avatar
SO, question for Ronnie & Tony
When using a "torque plate" do you torque it to the block just like a head to duplicate a head being on the block (So to speak)???
Old 11-03-2025, 03:33 PM   #12
Ronnieroadster
Yes that's exactly what we do torque to the amount desired aluminum head would be less than a stock iron head. Between the torque plate and the block I used a solid copper head gasket. The gasket is used to represent as close as possible the distortion produced between the two surfaces.
My torque plate was machined from a 1 inch thick piece of steel plate that was ground perfectly flat prior to drilling the 24 bolt holes and the cylinder bores which are 3-3/8 diameter on mine also we did not cut out the valve area. Ronnieroadster
Old 11-03-2025, 05:39 PM   #13
tubman
tubman's Avatar
A technical question for Ronnie. Why did you not cut out the valve area? It would seem that if it were cut out, it would more likely duplicate the deformations and stresses etc. of a stock head being torqued. I realize I am probably splitting hairs, but I'm just curious.
I realize that cutting them out probably wouldn't change a thing.
Old 11-03-2025, 06:26 PM   #14
KiWinUS
KiWinUS's Avatar
Same procedure for me as Ronnie.
Here is my plate.
Old 11-03-2025, 06:36 PM   #15
petehoovie
petehoovie's Avatar
Here is my plate.
Old 11-03-2025, 06:39 PM   #16
3W Hank
I cant see the distorotion if round or open up chambers, what the effect we like to see is the drag on bolts as on some engines its a problem, some not.
In the 80’s we was into heat hone ( with TQ plates on ) but I has not heard about that for decades now.
Then in a running engine its hear/waterflow etc but main thing I call for is drag on bolts if it get any changes.
-If I could get those blueprints.
Old 11-04-2025, 04:01 PM   #17
Ronnieroadster
Since the critical area of distortion is the location of the holes around the cylinder bores. These holes are extremely close to the bore so my torque plate design with just the bore holes was a simple design that works fine. Note the holes around bores on the 21 stud block is even worse.
I already have a very good test fixture I use when pressure testing the flathead blocks for cracks. Any additional material removed to duplicate the valve pocket area on this plate would have been a waste of time.
Ronnieroadster
Old 11-04-2025, 04:07 PM   #18
tubman
tubman's Avatar
Thanks for the clarification. It makes perfect sense.
Old 11-04-2025, 05:41 PM   #19
3W Hank
There are no pictures of the TQ ( design ) on both BHJ and CCA but both are + 400.
I might get a BHJ, just to save up time.
Old 11-06-2025, 09:03 AM   #20
KiWinUS
KiWinUS's Avatar
My pics are of my CCA plate. First class guy to deal with.
