Old 10-22-2025, 12:29 PM   #1
exoilfld
Default Backfire
I have a new French flathead with an 8ba front and 59ab bell housing converted to 12 bolts with a new vacuum distributor and new carb. It runs good at idle but backfires through carb on accleleration. Timing with vacuum attached is about 2 degrees. I have replaced the power valve but no change. Any ideas?
exoilfld is offline   Reply With Quote
Old 10-22-2025, 03:07 PM   #2
mfirth
Default Re: Backfire
I'd check for a vacuum leak, maybe lean fuel .... ??? Backfiring through the carb sure can damage the power valve.
mfirth is offline   Reply With Quote
Old 10-22-2025, 06:24 PM   #3
Doublepumper
Doublepumper's Avatar
Incorrect firing order or valve lash too tight are a couple other causes.
Ever stop to think and forget to start again?
Doublepumper is offline   Reply With Quote
Old 10-22-2025, 06:28 PM   #4
hueyhoolihan
lordy...i'd sure be hoping i'd screwed up the firing order. ha
hueyhoolihan is online now   Reply With Quote
Old 10-22-2025, 10:24 PM   #5
Flathead Fever
Flathead Fever's Avatar
Like others have said I'd check the firing order. Remember that the cylinder numbering on a flathead is not the same as other Ford V8's. You can have two cylinders mixed and it might idle just fine until you step on the gas. There is lots of diagrams on YouTube to double check it. If that doesn't fix it, then you need to figure out if it's fuel or engine mechanical. You can try spraying a can carb cleaner into at the spot it misses at and see if it gets better. That might determine if it's a fuel problem or something else.
Flathead Fever is offline   Reply With Quote
