Old 10-08-2025, 07:03 PM   #1
Bruce_MO
Default Stromberg carb question- no markings
I recently came across a Stromberg carb, that I’m pretty sure was last used on a ‘50 convertible. It is complete and in good shape, but it has no “97” or other designation on the body. I don’t know much about Stromberg carbs and have never had one on any of my flatheads. What does it mean to have no designation? Is it valuable? Thanks in advance to you Stromberg experts.
Bruce_MO is offline   Reply With Quote
Old 10-08-2025, 08:07 PM   #2
alchemy
alchemy's Avatar
Default Re: Stromberg carb question- no markings
It’s a 48. Larger than a 97, but doesn’t have the “fame”, so not quite as valuable.
alchemy is offline   Reply With Quote
Old 10-08-2025, 08:35 PM   #3
big deuce
big deuce's Avatar
Look for the 1 1/32" inside of a circle on the right (pass) side, behind the choke linkage.
big deuce is offline   Reply With Quote
Old 10-08-2025, 10:41 PM   #4
cas3
Refresh my memory, what years were the 48's used ?
Old 10-08-2025, 11:24 PM   #5
big deuce
big deuce's Avatar
1934
Old 10-08-2025, 11:25 PM   #6
petehoovie
petehoovie's Avatar
1934 for sure...1935 & 1936 until the 97's were introduced?...
Old 10-09-2025, 04:17 AM   #7
Brian
Brian's Avatar
Have none of you guys noticed the ported vacuum take off on the back of this carb? Didn’t stromberg make such a replacement carb for 8BA’s in the 50’s?
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 10-09-2025, 06:55 AM   #8
alchemy
alchemy's Avatar
It has the proper 48 top casting (no detent plunger for the choke). What size is cast on the back of the bottom? I can’t read the pics on my small phone screen.
Old 10-09-2025, 07:42 AM   #9
Terry,OH
Terry,OH's Avatar
Main body made in Elmira, NY. is different than the typical 97 or 48 made in South Bend. The base has a vacuum port cast into the body, which is not 97 or 48. My guess this Carb. was made for a car other than Ford.
Old 10-09-2025, 07:50 AM   #10
big deuce
big deuce's Avatar
It's the EE-1 base... just remove the base and measure the venturi.
Old 10-09-2025, 08:22 AM   #11
51504bat
51504bat's Avatar
Uncle Max might know.
Uncle Max's 97-Express | Genuine Stromberg Carburetor Parts and Service – We Repair and Remanufacture Stromberg Carbs
Old 10-09-2025, 07:01 PM   #12
uncle max
uncle max's Avatar
It's actually a replacement for the Holleys of the era, for use with the Loadamatic 8BA distributor, entirely different plumbing inside to capture venturi vacuum signal. Pep Boys, Sears and Western Auto and some Ford dealers were suppliers.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 10-09-2025, 07:04 PM   #13
uncle max
uncle max's Avatar
Originally Posted by brian View Post
have none of you guys noticed the ported vacuum take off on the back of this carb? Didn’t stromberg make such a replacement carb for 8ba’s in the 50’s?
bingo
Old 10-09-2025, 10:06 PM   #14
big deuce
big deuce's Avatar
What venturi size was it?
Old 10-10-2025, 02:54 AM   #15
Brian
Brian's Avatar
Thanks uncle max
Old 10-10-2025, 04:16 AM   #16
BlueNotes
I also have one and it’s marked ”31 32”, i.e. the venturi size is the same as the Stromberg 97.
BlueNotes is offline   Reply With Quote
Old 10-10-2025, 10:31 AM   #17
petehoovie
petehoovie's Avatar
Old 10-10-2025, 10:44 AM   #18
alchemy
alchemy's Avatar
^^^ You can tell that’s later production because it has a choke connection for a cable, not a ball/socket.
I’m going to have to dig through my boxes of carbs and see if I have any like that.
Old 10-10-2025, 05:06 PM   #19
big deuce
big deuce's Avatar
31/32= .96875 Looks like a comparable to a 97
Edit: Didn't see previous post...
Old 10-11-2025, 11:55 AM   #20
Bruce_MO
Thanks to all who responded. If anyone would be interested in it, PM me with what you think is a fair price. I’ve been asked to sell some parts for a guy whose estate is being sold off, to buy him a brick at the Model A museum at the Gilmore. He was a Model A guy for many years, and then a few years ago he bought a ‘50 convertible. The Stromberg was found in a Dennis Carpenter box that contained one of the new 94’s, so he evidently changed it out. Thanks
