#1 |
I'm looking at replacing the clutch and the rear spring on my '46, so the two jobs will go together when the time comes.
I've read posts on here, that suggests there are different size clutches. Is there a way to determine what size there is currently? Stock with a 59AB engine. What clutch supplier is recommended? Where is the best place to buy a spring and associated parts like bushings and links? |
#2 | |
Super Moderator
Supplier? NOT Ft.Wayne. Not anymore. Springs? Eaton Spring in Detroit is perhaps the best out there. A little costly for some guys but the spring will be built correctly for YOUR application.
#3 |
51woodie, how many leafs is your rear spring? There is a NOS 10 leaf spring on Ebay right now, item (126556379757). I think the price was $187. The "Green Bible" showed that is the correct replacement on my 48 business coupe but the sedan coupe may be different.
#4 |
Looked it up, sedan coupe is 11 leaves and part # 59A-5560-B. One NOS one on Ebay but at $400 I'd give Eaton a strong look. Perhaps Fred Wilner might have one at Southside Obsolete? Worth a call.
#5 |
I have just ordered a set of springs from eaton, for my 34 , they seem very professional to deal with, told me 6 weeks ,but 3 weeks and they are on their way,
should be here in a few days . Lawrie |
#6 |
#7 |
I have had poor luck with new clutch disks supplied with the new replacement clutches for flatheads. The new disks have no "marcel", the internal wavy spring between the friction linings that helps prevent clutch chatter. I look for NOS disks at swap meets and occasionally on ebay. If the pressure plate looks acceptable I reuse it.
#8 |
I’m with 38 Coupe . Good used beats new nowadays.
#9 | |
Try Kentucky Clutch Home | Kentucky Clutch | Car, Tractor & Truck Clutch Repair & Kits
Making the simple complicated for over 30 years. |
#10 |
I have nos govt 10” discs and have been selling them for 30-40 years.
#11 |
Super Moderator
Doesn't get any better than this!
