Old 10-05-2025, 12:01 PM   #1
ckh
Default 1937 21 stud engine info
I believe FoMoCo changed main bearings from babbit to inserts at some point
in 1937. Is this correct? If so, what was the last engine # that had babbit
bearings? All replys appreciated.
Thanks,
CKH
ckh is offline   Reply With Quote
Old 10-05-2025, 12:10 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: 1937 21 stud engine info
Mid 36. Engines do not have any kind of serial number.
Old 10-05-2025, 12:15 PM   #3
Ggmac
Agreed , mid 36 . I have 2 very good running motors . Both have hps ? Stamped on block / head surface . I have no idea what it means , hard seats ? , hard sleeves and pistons? Which one still had , standard bore , no ridge .
Ggmac is offline   Reply With Quote
Old 10-05-2025, 12:26 PM   #4
ckh
Thanks KiWinUS nd Ggmac. That's just the info I needed. Went through the hassle of
having the babbit replaced in an early 36. Never again!
CKH
Old 10-05-2025, 03:40 PM   #5
nelsb01
nelsb01's Avatar
I have a late 1936 21 stud with LB stamped on the block surface. I think that is how the late 1936 blocks were labeled.
nelsb01 is offline   Reply With Quote
Old 10-05-2025, 04:12 PM   #6
Ggmac
Too many fake LB stamped blocks .
Old 10-06-2025, 05:32 AM   #7
glennpm
glennpm's Avatar
FoMoCo changed main bearings from babbit to inserts with the LB blocks
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 10-06-2025, 05:42 AM   #8
38 coupe
38 coupe's Avatar
Ford produced babbitt main blocks along side insert main blocks from late 1935 through the end of 1936 model year production. This is typical of Ford practice at the time, using some part of the population to test a change while continuing the old method at the same time.
Not all LB blocks are stamped, the one dad picked up to use in my brother's 32 does not have any stamped markings indicating the insert mains.
Old 10-06-2025, 06:44 AM   #9
Ggmac
The 2 I have do not have LB stamped. Ive had a few that were babbit and one of those were stamped LB . Probably to raise its resale value.
Old 10-06-2025, 02:12 PM   #10
Lawrie
Lawrie's Avatar
all the 36 blocks I have seen have a small hole(about1/2 -5/8) in the lower front right of the engine block down by the fan pulley, will post a pick later this morning,
Lawrie
Lawrie is offline   Reply With Quote
Old 10-06-2025, 04:17 PM   #11
Lawrie
Lawrie's Avatar
Picture o
Old 10-06-2025, 05:40 PM   #12
petehoovie
petehoovie's Avatar
Originally Posted by Lawrie View Post
Picture o
Old 10-06-2025, 08:23 PM   #13
34fordy
34fordy's Avatar
Lawrie
What do you feel this indicates Lawrie?
34fordy is offline   Reply With Quote
Old 10-06-2025, 10:04 PM   #14
Brian
Brian's Avatar
those holes are present in all Canadian engines with liner main bearings, ie 36 LB on.... Quick and easy way to identify LB 36 engines. American engines didn't have that feature. There is another of those holes at rear of those blocks, can't see it with the oil pan on. I assume they were drilled during manufacture to be used to locate the blocks in fixtures for machining.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 10-07-2025, 12:41 AM   #15
Lawrie
Lawrie's Avatar
I think you are right Brian.
unfortunately this block ended in the bin, Way too rusty in the bore to reclaim
the hole down the back of the block is a larger one, maybe so the block only went one way on the Jig.
Lawrie
Old 10-07-2025, 05:03 AM   #16
Ggmac
I checked my 2 lb 36 motors and no holes .
Old 10-07-2025, 05:04 AM   #17
38 coupe
38 coupe's Avatar
Here is a picture of a Canadian engine with the oil pan off showing both the holes discussed by Lawrie and Brian:
Old 10-07-2025, 05:34 AM   #18
glennpm
glennpm's Avatar
Pages 296 and 298 from https://www.dropbox.com/scl/fi/sfxwc...=24fyili9&dl=0
Rumble Seat’s Notes
