Old 09-20-2025, 10:51 AM   #1
flathead4rd
flathead4rd's Avatar
Default Lifter Problem
I have one (1) lifter that won't hold it's setting. Can this be fixed without having t0 remove the head? If so, all suggestions will be welcome.
flathead4rd is offline   Reply With Quote
Old 09-20-2025, 12:05 PM   #2
tubman
tubman's Avatar
Default Re: Lifter Problem
Mr. GOOGLE says : "Green Loctite is primarily used as a high-strength, low-viscosity anaerobic adhesive for locking preassembled threaded fasteners." You can get at it by removing the intake manifold.
Sounds like it might work.
tubman is online now   Reply With Quote
Old 09-20-2025, 12:59 PM   #3
Drbrown
Drbrown's Avatar
I assume this is about Johnson Style adjustable lifters. Never done it but if the threads on the lifter's adjustable bolt are covered with oil, its may be difficult to clean-off enought oil so the locktite wsill adhere ? Old posts here about this problem = one responce was to get the lifter properly adjusted then use a pointed tool punch to moderately "upset" the exposed treads on the lifter bolt enough that it prevented to lifter adjuster bolt from easily turning and getting out of adjustment. This at least would avoid removing the head to replace the lifter.
Drbrown is offline   Reply With Quote
Old 09-20-2025, 01:08 PM   #4
tubman
tubman's Avatar
As always, try the "non-destructive" method first. And notice; the Loctite is specifically designed for assembled threads.
Old 09-20-2025, 02:31 PM   #5
40cpe
40cpe's Avatar
Belt and suspenders: Extend the adjuster to expose the threads that were in the lifter threaded area. Clean the oil from the threads with brake cleaner, Place a rag behind the threads to absorb as much as possible. Use a suitable tool to "ding" the threads that will be in the lifter when adjusted. Apply loctite and readjust the clearance.
40cpe is offline   Reply With Quote
Old 09-20-2025, 06:53 PM   #6
Angledrive
Angledrive's Avatar
I agree, that is how I have done it.
Angledrive is offline   Reply With Quote
Old 09-21-2025, 07:56 AM   #7
GB SISSON
GB SISSON's Avatar
I also agree with the double whammy. Last time you'll have to deal with that lifter. Glued, screwed and tatooed.
Old 09-21-2025, 10:01 AM   #8
flathead4rd
Thanks to all who replied. I just got this engine back in the car with everything hooked up and upon starting it up had a lot of lifter noise. Only sounds like one. I will try one or more of the suggested remedys. Only removing the intake will save a ton of time which at age 86 is important. Will keep you posted on the results. Thanks again guys.
Old 09-21-2025, 05:48 PM   #9
40cpe
40cpe's Avatar
If it was making noise on first start maybe it/they weren't adjusted correctly at installation. Maybe try an adjustment first?
