Old 08-09-2025, 10:25 PM   #1
ironmountain
Default Transmission main shaft
I have a transmission apart at the moment. The vehicle it was out of (1929 Canadian assembled) was originally a multi disc clutch vehicle which has since been replaced with a single plate clutch.
The main transmission shaft did NOT have a spacer ring on it when it came apart. it does have a lip/flange on it at the bearing race end of the main shaft.
What is correct? should it have a spacer or not. Does anyone have a picture of the difference between shafts?
ironmountain is offline   Reply With Quote
Old 08-10-2025, 12:59 PM   #2
Tom Endy
Tom Endy's Avatar
Default Re: Transmission main shaft
The early shafts had a built-in spacer. The later had a removeable spacer much like a key ring. The later should be replaced at overhaul as it will be worn flat on the front side. Do not use a later on top of an early'
Tom Endy
Tom Endy is offline   Reply With Quote
