Old 08-06-2025, 01:54 AM   #1
fortyonerag
fortyonerag's Avatar
Default Oil transfer - recommendations?
I’m planning an oil change for both my gearbox and differential. Stock 41 side shift box and banjo. Last time this was a pretty laborious operation lying on the floor with a hand operated pump for quite a while.
Floor is pretty cold down under this time of year. Thought I’d ask what are you folks using for moving thick oil?
fortyonerag is offline   Reply With Quote
Old 08-06-2025, 05:22 AM   #2
38 coupe
38 coupe's Avatar
Default Re: Oil transfer - recommendations?
I only know the hard way, using an oil suction gun. Slow and messy.
Old 08-06-2025, 06:13 AM   #3
Terry,OH
Terry,OH's Avatar
Remove the drain plug at the bottom of the cases. No need for a pump to remove oil.
Old 08-06-2025, 07:55 AM   #4
fortyonerag
It’s not the removal, gravity takes care of that. Getting oil back in is the challenge. What are you guys using to get thick oil back in?
Old 08-06-2025, 08:06 AM   #5
Zax40
Zax40's Avatar
Use both a ketchup style squeeze bottle and a gear oil pump. I have used the cheap squeeze bottles for corn head grease, brake fluid, gear oil. They do pretty well if there is room.
https://www.amazon.com/dp/B07QQVCRSD...n_title_2&th=1
Zax40 is offline   Reply With Quote
Old 08-06-2025, 09:49 AM   #6
Kens 36
Kens 36's Avatar
I use a gear oil pump similar to this one from Harbor Freight - about $10 US. Don't know what suppliers you may have.
Ken
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 08-06-2025, 12:40 PM   #7
J Franklin
J Franklin's Avatar
Heat is your friend.
Old 08-06-2025, 06:58 PM   #8
leon bee
Yeah, wrong hemisphere, something like that. Gear oil is really thin now in Arkansas.
leon bee is offline   Reply With Quote
Old 08-06-2025, 07:03 PM   #9
coolcoupe
coolcoupe's Avatar
I just changed mine both tranny and diffy , I used a squid can worked fine
coolcoupe is offline   Reply With Quote
Old 08-06-2025, 09:04 PM   #10
19Fordy
19Fordy's Avatar
I have found that using a caulking gun works best for filling if you have an old empty caulking tube. Insert the empty caulking tube in the caulking gun, fil it with gear oil, replace the plastic "plunger" and squeeze the trigger to fill transmission or rear end.
Old 08-07-2025, 07:16 AM   #11
Terry,OH
Terry,OH's Avatar
Some of the fluids come in a soft plastic bag you can roll up and the fluids come out. I have been using the pump as shown above #6 post. Only draw back is limited space under the car but just jack it up. The pump will fit quart containers and the 1/2 Gal size.
Old 08-07-2025, 07:33 AM   #12
fortyonerag
I have a hand pump, but I’m starting to suspect it may be a bit small. Took a few hundred pumps to fill the gearbox last time. Was like filling it up a spoonful at a time.
I was running 80W-90, but it was suggested I try something thicker, which I did. It might be the cooler weather but the synchros don’t work so well with thicker oil - wear might be an issue, so I’m looking to revert.
Before I go through the hassle of the refill I thought I’d ask. Many thanks for the suggestions all.
Old 08-08-2025, 01:31 PM   #13
Karl Wolf
Karl Wolf's Avatar
With a floor shifter, (Model A) I remove the shifter and pour it down through that, until it comes out the fill hole in the side. Yes, no help for colum shifters
If I have to fill the rear end, I use a long piece of 3/8" or larger fuel hose- tape part of it to a stick so no sagging, takes a lot of time, but I am in no hurry...
Karl
Karl Wolf is offline   Reply With Quote
Old 08-08-2025, 04:37 PM   #14
Adam/Mill Valley CA
Adam/Mill Valley CA's Avatar
I use a pressure setup-got tired of using the hand pump (as shown in the above post) while lying under jack stands. Made from a garden sprayer, some 3/8 tubing and a shut off valve, just pressurize it, put the hose end in the filler hole, and open the valve-works fine with 80-90W gear oil, not sure how 140 weight would be.
Adam
1936 pickup, stock, black
1965 Mustang coupe 289/4bbl, black/red
1971 Alfa Romeo GTV 1750 coupe, dark red/tan
1970 911E 2.2 litre dark blue/black
1968 BMW R50/2 US, black (m'cycle)
1967 Triumph TR6R , sea foam/cream (m'cycle)
2022 Royal Enfield Interceptor 650 red (m'cycle)
1974 Honda CB750 red (m'cycle)
2000 Kawasaki W650 blue/silver (m'cycle)
Adam/Mill Valley CA is offline   Reply With Quote
Old 08-08-2025, 05:38 PM   #15
petehoovie
petehoovie's Avatar
Adam
Old 08-08-2025, 07:29 PM   #16
leon bee
I like Adam's little rig up there, gonna remember that.
