Old 07-31-2025, 11:34 AM   #1
Stephenorf
Stephenorf's Avatar
Default Stabilizer Bar To Frame bushings - 1959 - 1964
Does anyone know if the 1959-specific B9MM-5484-A bushing will crossover to the later 1960+ bushings? I can find plently of B9A-5493-B bushings for sale, but the B9MM-5484-A bushings are rare as hen's teeth and pricey too.
1959:
1960-1964:
Thank You,
Stephen
Stephenorf is offline   Reply With Quote
Old 08-02-2025, 10:18 AM   #2
Stephenorf
Stephenorf's Avatar
Default Re: Stabilizer Bar To Frame bushings - 1959 - 1964
ok, I measured the diameter of the sway bar in my 1959 Mercury Monterey. It measures right at 7/8" (.875). Now I'm on the hunt for a sway bar bushing that will work.
Old 08-02-2025, 02:18 PM   #3
miker98038
miker98038's Avatar
Don’t know if it will help, but here’s a chart. I’m not a big fan of hard bushings (I’ve had to many squeak, dispite what they say) but a start.
https://www.suspension.com/universal...r-bushings.asp
https://www.suspension.com/9.5158
miker98038 is offline   Reply With Quote
Old 08-06-2025, 08:00 AM   #4
Stephenorf
Stephenorf's Avatar
OK, I decided to take the old bushings off the car. They are definitely unique-looking bushings. They are teardrop shaped rather than the normal semi-circle type shape. Does anyone with earlier makes/models recall similarly shaped sway bar bushings?
Old Bushing - Obvously worn out...
In case anyone was wondering....This is the semi-circle shape of most modern sway bar bushings....
Old 08-06-2025, 08:03 AM   #5
Stephenorf
Stephenorf's Avatar
Thanks, I checked this chart out. It has good specs for IDing bushings, although I too do not like the hard bushings and prefer regular rubber bushings. Evidently the bushings on my 1959 Mercury Monterey are not shaped like a normal sway bushing.
Old 08-06-2025, 09:26 AM   #6
Stephenorf
Stephenorf's Avatar
Here's some similarly shaped bushings for a later Mercury/Lincolns. It seems at least these are the right shape. I might try to get these to work. The engineering part number for 1959 Mercury Monterey is B9MM-5484-A wich I cannot find anywhere.
Old 08-06-2025, 04:38 PM   #7
raceron1120
raceron1120's Avatar
I have a couple of boxes of sway bar bushings but don't remember the diameter. UPDATE - I checked and nope, too big. sorry.
raceron1120 is offline   Reply With Quote
Old 08-06-2025, 04:58 PM   #8
Stephenorf
Stephenorf's Avatar
Alright! Thanks a million let me know what you find. Much appreciated! Update - thanks for looking!
