#1 |
Hi, sorry for my lack of a better technical language. As the title says, the emergency brake handle suddenly stop working. The car left Florida with all working. Sent to MA in an enclosed truck of a professional car transportation company. At arrival, the emergency brake was not working at all. When it is pulled to the back, returns to the front. It's not staying in position and not braking.
Please, can you provide me some guidance what do I have to look or in other words, what could be the problem. Thank you, Dan |
#2 |
Sounds like the actuating rod fell off during transportation. Do you see anything dangling underneath?
Ruth "Sometimes you really DO need to read the whole thread" |
#3 | |
![]() Quote:
Removing those pins will free the "hook type piece" ? And, how to reassemble it engaging what teeth? Thank you !! Screenshot_20250728_151631_WhatsApp.jpg Screenshot_20250728_145947_WhatsApp.jpg |
#4 |
Hard for me to see in the pictures, but it looks like someone just pulled the lever back too far. Pull it back an see if you cap "flip" the pawl back onto the teeth. I'm not that familiar with the early parking brake.
#5 |
For whatever reason,the moving pawl has jumped up over the fixed pawl.Not sure how it happened,but there it is.Go to the opposite side of the pivot,towards the drivers foot,and take the pinch bolt out.Slide the lever through the cast pivot until the ratchet pawls clear each other.Turn the moving pawl down to where they will engage,and slide it all back together.Then track down as to whay it happened.I suspect the parking brake was adjusted too loosely,and when somebody pushed their thumb on the button and pulled to release it,the pawl just popped up over the fixed part.Nobody actually did anything to break it.
#6 | |
1000076494.jpg Is there anything else I should be aware of, like anything that should be loose / disengaged before removing that bolt and sliding the lever? |
#7 | |
![]() Quote:
Fixed, thank you !!! On the way you suggested that I quoted. Here are some images. |
#8 |
Something that just occured to me.You MAY be able to take the pin out of the clevis on the riders side brake rod,and pull that lever back far enough for the parts to be turned back to where they belong.You MAY also be able to push the button down,and pull the lever back hard enough to roll the pawl back down into place.Things never pop back into place as easily as they popped out though.When properly adjusted you should be able to go from free wheeling to locked up in three clicks.
#9 |
fixed, thank you.
#10 |
You can see now just what happened.You should not have to pull that lever back that far to operate the parking brakes.If you can tighten the rod adjusters to the point that the wheels are locked at 3 clicks,and not drag when released,you'll be all set.
