Old 07-28-2025, 10:36 AM   #1
Ohc Joe
Default 1936 sedan sway question thoughts ideas???
Hey guys
So im back on working on my daughter's 36 sedan school starts soon and she wants to drive it .
So is there any suspension kits for this car so she doesn't sway So much around corners..
All stock suspension with the dog bone shackles things for a little bit of lowering along with the front spring
Thanks guys again
Ohc Joe is offline   Reply With Quote
Old 07-28-2025, 11:07 AM   #2
petehoovie
petehoovie's Avatar
Default Re: 1936 sedan sway question thoughts ideas???
Originally Posted by Ohc Joe View Post
Hey guys
Thanks guys again
Old 07-28-2025, 11:14 AM   #3
Ohc Joe
Im looking to see if anyone has done one of these shock kits I see online if so thoughts
This is a simple build nothing crazy
Old 07-28-2025, 11:17 AM   #4
TJ
TJ's Avatar
If you used longer shackles you have answered your own question. That is your sway problem. You should use a dropped axle with stock shackles and a tube shock kit on front and rear. You can lower the rear by having a spring shop lower the arch of the spring. If you still have mechanical brakes the dropped axle will not work with them.
Old 07-28-2025, 01:04 PM   #5
Ohc Joe
Yep....ok cool deal
Yeah using mechanical brakes
Will look up those tube shock kits also
Thank u
Old 07-28-2025, 07:17 PM   #6
Brian
Brian's Avatar
Actually, you can run a dropped axle with mechanical brakes; I have done so on my 35. if you run, say, an Okie Joe dropped 36 axle, all you need to do is heat and bend the curved piece at the top of the perch bolt to reconfigure it to suit the brake actuating cross shaft. And bend the rubber anti rattle things located half way along the radius rods so the rods can pull straight.
Easy to lower the back of that car too....you can fit lowering blocks between the radius rods and rear axle housings. I made my own, but there is someone in the states that sells them.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 07-28-2025, 07:25 PM   #7
Brian
Brian's Avatar
https://carrillocustoms.com/products...ering-brackets
https://www.fordbarn.com/forum/showthread.php?t=58142
Old 07-29-2025, 10:06 PM   #8
Ohc Joe
Thanks
