#1 |
I just replaced the four bladed fan on my Model A. I've had the new two bladed aluminum fan for several months. There was some noise coming from the front of the car but I couldn't tell if it was the four bladed fan or the generator. It was a good time to do the fan replacement job. I got the fan pulled from the water pump and mounted the new fan. It fit very closely but it went together except for the castle nut on the shaft. I tightened the nut as far as I dared, but didn't like the fit of the nut. I cheated, and took a hack saw and deepened the slot for the cotter pin. I almost felt myself looking around the shop to see if anyone was watching me! I even took the next smallest cotter pin to complete the installation. I hope I don't pay the price for lousy work. Am I the only one who occassionally has to do this?? By the way, the noise went away and the new fan looks great. Ed
#2 |
did you put a thin washer on before the nut ?? if not go back & do it , the nut will chew into the alloy & it may come loose .
#3 |
its only you............
#4 |
X2 on a thin hardened washer. I lapped the fan to the shaft with valve grinding compound then checked it with prussian blue.
#5 |
#6 |
In your case, you probably had to use a reproduction water pump rebuild kit, a re-cored or reproduction radiator and a reproduction fan blade, which may or may not be of good quality (lots of two-blade fan iterations sold to us over the years), but is NOT a genuine Ford replacement part. Putting all these repro parts together to make a functioning and reliable cooling system will require at least some degree of corrective modifications. You did what had to be done in 2025 to make 1928-31 Model A components work. No shame. Marshall |
#7 |
#8 |
It's not a matter of cheating but rather a question of maintaining safety and reliability in your (our) antique vehicles while being out on public roads .... I have cheated too, but where it's a question of being SAFE, I would rather err on the conservative side and be SAFE doing the repair or upgrade the correct way and coming as close as possible to what is considered a safe and reliable long lasting fix.
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
#9 |
You need to be resourceful when owning a Model "A".
Bob Bidonde |
#10 |
There is a very fine line between a hack job and being creative or "cheating". Getting to the root cause of a problem is often the challenge.knowing what is right or wrong takes some research/education/experience. having the right combination of knowledge AND the right tools is often not in the equation. This is where having an experienced model A buddy and or clubs can make a huge difference in the outcome/safety of a repair. The preponderance of almost right parts only clouds the issue. Just remember there is no substitute for experience and knowledge. It behooves anyone who is attempting repairs to seek those out. Even with a model A the problems/repairs can be more complex than appears. The root cause of a problem is often masked by layers of other problems.
#11 |
"...the root cause of a problem is often masked by layers of other problems..."
...and ignored or glossed over by subsequent owners over the years. WE are the ones left holding the bag to undo past sins heaped upon our Model A's. It seems that I spend more time UN-doing hack work than I do making the actual repair. Some of these "repairs" are ingeniously stupid and must have required more time and effort to do than to have actually made the repair properly in the first place. And these idiots reproduced and voted??? Marshall |
#12 | |
![]() Quote:
#13 | |
![]() Quote:
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
