Old 07-24-2025, 09:17 AM   #1
Patrick brophy
Default correct size of battery for a 1957 thunderbird
i has a situation with the battery size in my 57 Thunderbird. I am in the finishing stages and was starting and running the motor to make a few adjustments etc. and all was well.
I closed the hood and it stalled. I opened the hood and restarted it and everything appeared to be fine. I closed the hood and it stalled again.
It was then i noticed that the positive battery post and clamp had shorted out against the underside of the hood burning a really nice black hole in my brand new white paint job. Apparently this battery sits to high.
The battery is 8 inches high and the post is 9 and 1 quarter high. It is 12 and a half inches long. and 5 and a half inches wide.
Would any know the correct size for this battery in this car?
the battery is a Deka 650 MF 600 108 RC
Patrick brophy is offline   Reply With Quote
Old 07-24-2025, 10:05 AM   #2
KULTULZ
KULTULZ's Avatar
Exclamation Re: correct size of battery for a 1957 thunderbird
Pat, the DEKA APPL CHART shows that BATT @ 8.875" H
Is the case 8" H or is it case and post(s)?
OEM FORD (BIRD) was 8"H (taking into consideration correct battery tray).
Did DEKA cataloging show that BAT as correct service replacement for the BIRD?
See if the OEM application chart shows -
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 07-24-2025, 10:40 AM   #3
Patrick brophy
Default Re: correct size of battery for a 1957 thunderbird
The battery is 8 inches high. 9 1/4 high at the top of the positive post.
The auto parts dealer did not have this car battery listed in their Deka book. They contacted Deka and made a special order.
This was a year or so back.
Old 07-24-2025, 04:46 PM   #4
KULTULZ
KULTULZ's Avatar
Arrow Re: correct size of battery for a 1957 thunderbird
Ain't that the way it always is?
BATT SIZE and SOURCE - https://www.wholesalebatteries.net/p...24-60-warranty
Even if you put some type of protective blanket (rubber) over, it might shift and burn the car up and still rub the underside of the hood. OEM calls out 8" (so does my old lady). I don't know if that height is with or without posts.
What do you think you will do. The things aren't cheap anymore.
Old 07-24-2025, 07:49 PM   #5
paul2748
paul2748's Avatar
What is the battery model? number. Two different batteries were used in 57 Birds, 29NF and 32 NF. The 32 NF is not commercially available (expensive repos may be available) and there have been some problems getting the 29NF
How is your battery oriented? The posts on a stock battery are on the inside toward the engine., positive in front, negative in rear toward the firewall.
Based on a generic listing of batteries I have, the 29NF is listed as 13 L, 5 1/2W and 8 15/16 H. No listing of the 32 NF
There are battery post covers available, but not sure these will help if tolerances are so close
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 07-25-2025, 09:42 AM   #6
dmsfrr
dmsfrr's Avatar
Example photos below. If the battery posts are toward the fender they may touch the fender or outer framing on the underside of the hood.
For whatever it's worth... I measured the overall height of a NAPA 29NF battery here that was removed from a '57 T-Bird. The tops of the posts are approx 9 to 9 & 1/8 inches up from the bottom of the battery.
That's a good point... after 65+ years the battery tray may not be original to the car.
Or, due to the narrowness of the metal tray the existing battery may not be sitting flat in the tray.
Or, there may be something under the battery to raise it slightly so it isn't cut into by the tray edges.
File Type: jpg DM 57 engine compartment - Positive.jpg (90.0 KB, 22 views)
dmsfrr is offline   Reply With Quote
Old 07-25-2025, 01:18 PM   #7
Patrick brophy
Paul hit the nail right on the head.
The battery I had, Deka, had the posts towards the outside of the car. The interfered with the structure of the hood.
I went to the local tire dealer who sells Interstate battery's. He contacted the dealer rep. who was most helpful, and knowledgeable.
He was aware of the issue with the baby bird hood and the position of the post.
They had a Series 29 battery where the positive post would be positioned in front and on the inside of the battery.
It was also a considerable amount cheaper than the Deka.
Thanks for all the help and comments .
Old 07-25-2025, 04:52 PM   #8
KULTULZ
KULTULZ's Avatar
Thumbs up Re: correct size of battery for a 1957 thunderbird
Ain't that something? We all learned something today ...
EDIT -
So if the BATT is installed incorrectly (or wrong BATT in this instance), the posts will hit not the hood skin itself but the hood frame.
Did you take a photo? How badly was the paint damaged?
Last edited by KULTULZ; 07-26-2025 at 12:37 AM. Reason: 2nd THOUGHTS and CIPHERING
Old 07-26-2025, 03:03 PM   #9
Patrick brophy
I forgot to take some photos.
The damage was limited to the shape of the positive terminal end of the battery cable burned thru the paint and into the metal on the underside of the hood.
Some masking, grinding, sanding and body filler later I was ready to paint it with my airbrush.
Expensive error on my part.
Old 07-27-2025, 01:46 AM   #10
KULTULZ
KULTULZ's Avatar
Post Re: correct size of battery for a 1957 thunderbird
Well, it happens.
Had the replacement been closer in time, you should have caught the wrong BATT.
A nice STEAK and CHEW with a few cold adult beverages will dampen the hurt ...
A little out of date, but good info here - https://www.ctci.org/batteries-revis...-thunderbirds/
NOTE : Antique Battery, Youngstown Ohio Was Bought By -
- https://www.jimsbattery-mfg.com/
ALSO - BATTERY DECORATION -
- https://weskcar.com/
