#1 |
Could somebody please tell me the Timken bearing numbers for the back axle . My bearings are marked A 4221 N for the cone . For the supplier I need the Timken number . Thank you .
John still in Suffolk County England . |
#2 |
For the cone I have Timken 28317
For the bearing I have: Timken 28156
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 07-21-2025 at 10:21 AM. Reason: Correction |
#3 |
Thank you very much Katy
#4 |
are you talking about rear wheal bearings . thease part numbers are for front bearings
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
#5 |
I am talking about the pinion bearings and diff carrier bearings . Original marked A 4221for the cone .
#6 |
A-4221= Timken 28156, A-4222= Timken 28317 |
#7 |
Thank you Bob C My supplier has the cone for £ 54 about $70 for Timken Japan NTL about half that .
#8 |
Location: North Warrandyte, Melbourne,Victoria, Australia
NTN are 2nd best brand of tapered roller bearings as they use the exact,precise, same case hardening as TIMKEN &they're usually cheaper btw/fyi: NTN OWN BCA/BOWER&SNR (FRANCE) bearing companies.
#9 |
to anyone,
does anyone know the Timken number for the drive shaft bearing, A-4645? and the seals, A-4625? Diastole in the Smokies
A little learning is a dangerous thing. Drink deep, or taste not the Pierian Spring; There shallow draughts intoxicate the brain, and drinking largely sobers us again. |
#10 |
I looked in my bearing interchange and there is no Timken number for A-4645. The number for Hyatt, RBC, Berliss or ABC
is 99061. |
#11 |
Lets complete the circle of bearing conversion numbers. What are the Timken or Hyatt or ? bearing numbers for the transmission, steering and spindle bolts?
Bob Bidonde |
#12 |
Try this (I couldn't find the thread)
Differential A–4221 Pinion/differential bearing 28156 Timken A–4222 Differential race? 28317 Timken A–4245–A Rear axle grease retainer 1575 Chicago Rawhide 459945 National Drive shaft A–4645–B Drive shaft roller bearing 1–131436 SKF 193801 SKF J35–1957 Bowers 99061 Hyatt modified drive shaft roller bearing 4024 NCS 2 req Drive shaft sleeve race PI3 24024 NCS 2 req Drive shaft grease seal C2122 NCS 2 req Crankshaft A–6340 Crankshaft rear bearing shim 1505M 1/32 Federal Mogul A–6346 Crankshaft front/centre shim 1505M 1/32 Federal Mogul Oil pump A–6612–AR Oil pump bushing 4365 Clevite 2 req A–6612–B Oil pump bushing 4265 Clevite 2 req Gearbox A–7025 Transmission main drive gear bearing 306P Timken 1–114118 SKF 1 side sealed 306SZ SKF 3208 ND A–7065 Transmission main shaft bearing 1–114119 SKF 1 side sealed 208SZ SKF 1306 Federal A–7118–A Countershaft Short bearing 24780 Timken F–93324 SKF J24–1256 RHC 93328 Hyatt J–24–1248 BCA Federal Mogul A–7121–A countershaft long bearing J–24–1256? BCA Federal Mogul 94216 Hyatt J201632 Bowers J–24–1256? BCA Federal Mogul Clutch A–7580–B Clutch throw out 2065 BCA Federal Mogul 400196 SKF A–7600–A Pilot bearing standard 6203–2RS SKF A–7508–B Clutch/brake shaft bushing 02110 Clevite Water pump A–8530–A Water pump roller bearing J201632 BCA Federal Mogul substitute bearing BF–1416 Torrington substitute race IR–101416 Torrington Generator A–10093–AR Generator shaft large 6204 Fafnir A–10094 generator small shaft 6203–2RS BCA Federal Mogul substitute bearing A4059 BCA Federal Mogul substitute race A4138 BCA Federal Mogul A–10095–AR Generator com end E15 BCA Federal Mogul substitute bearing sealed 6202RS General A–10095–AR generator pulley end 203SZZ Timken Posted by Bob Barker from cpe-24-95-52-135.columbus.res.rr.com (24.95.52.135) on Wednesday, December 23, 2009 at 12:00pm: in reply to: re: pilot bearing posted by Gary–WA from wtcdsl-66-165-25-222.whidbey.net (66.165.25.222) on Wednesday, December 23, 2009 at 11:58am: Thanks Gary http://www.
