#1 |
How many red stripes are on the 40 ford hot water heater for sure 2 or 3 thank you jim
#2 | |
![]() Quote:
#3 |
I have that same heater in my 39 truck, albeit rough shape and non functional at the moment. Is that Ford product or after market? I would definitely like to restore it but didn't know anything about it to start the process.
#4 | |
![]() Quote:
The truck heater appeared very similar to the car heater. However, they mounted differently, and the inlet / outlet nipples were in different places than the car version. The truck version had a small drain plug at the bottom, the car version did not. Also, '39 heaters had squared of knobs vs. the rounded version in '40. The '39 heater body was a brown color vs. gray in '40. The toe guard in '39 was solid, in '40 it was vented. Noi stripes on a '39 heater, the '40 heater had three red horizontal stripes on its two sides. These stripes were approximately 1/8” wide and spaced approximately 5/16” apart.
#5 | |
