#1 |
How does one remove the upper interior window trim/molding from the rear (side) windows of a 30-31 tudor? I'm not seeing any clips or screws holding it in place.
Thanks |
#2 |
The upper rear corner of the quarter window trim ? Just pull it forward.
#3 |
If memory serves there’s a tab extending past that corner with a c’sunk wood screw securing it. The upper upholstery panel hides this fastener.
#4 |
You are absolutely correct. I found 2 tabs (welded) at the front end of the frame and a plate that kind of clamps it into place at the rear. Mine is a Canadian car btw. Once removed, pulling downward freed the trim from the car.
Thanks for the input. Are these pieces as hard to find as people say? I don't have the driver's side trim. |
#5 |
