Old 07-08-2025, 08:29 PM   #1
Mshaynes21
Default Coolant question
I noticed some coolant under my 30 A Roadster. I thought I might need to add some coolant in but as I was pouring it in it was coming out the overflow tube onto the ground. Does this mean the radiator was already too full? It was really hot today outside but the car hasn’t been running.
Thanks for any info!
Mshaynes21 is offline   Reply With Quote
Old 07-08-2025, 08:55 PM   #2
JayJay
Default Re: Coolant question
Maybe. On a Model A it’s pretty easy to pour coolant into the top of the copper overflow tube when you fill at the neck. Suggest that you carefully fill the radiator until it is just above the splash apron visible through the neck, close it up and drive it. The coolant will seek its own desired level and stabilize. After that, look for leaks on the ground.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
JayJay is offline   Reply With Quote
Old 07-09-2025, 03:22 AM   #3
nkaminar
nkaminar's Avatar
When I fill my radiator after draining it for some work on the engine, I use a funnel. That eliminates the coolant from hitting the overflow tube and keeps me from spilling it over my hood and radiator.
Old 07-09-2025, 06:10 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
This slide may help you.
Bob Bidonde
Old 07-09-2025, 06:55 AM   #5
brokenspoke
Put a roofing nail in the overflow tube
brokenspoke is offline   Reply With Quote
Old 07-09-2025, 07:28 AM   #6
nkaminar
nkaminar's Avatar
There was a service notice to bend the overflow pipe towards the front of the radiator to prevent excessive coolant loss. Just be careful to bend it gently and in a generous radius. The service notice is on page 450 of the Service Bulletins.
Old 07-09-2025, 08:03 AM   #7
Big hammer
WOW time flies , 55 years ago I chased my tail around looking for a reason why my A was over heating in the summer. Removed radiator and had it cleaned and repaired, removed and rebuilt the water pump, cleaned the block with a long cable poking around the rear cylinders, etc. I finally figured out letting it find its happy place just at the baffle, walla no more over heating ( overflowing) ! Wished we had the internet, I could have been having fun getting into trouble :-)
get a bigger hammer tap done
Old 07-09-2025, 08:48 AM   #8
chap52
chap52's Avatar
What Big Hammer said. Chap
chap52 is offline   Reply With Quote
