#1 |
Good morning, I inherited a ‘30 coupe that has a new V8 clutch and lightened flywheel. The clutch grabs very high before the car gets going. Is this to be expected or should it be adjusted accordingly? I don’t want to fix what’s not broken it just feels way too high to me.
#2 |
Should have 1 to 1 1/2 inch free movement at the top.
#3 |
Oh wow ok then that’s about right. Yikes I was worried about that! Thank you!
#4 |
I have a friend who would take his antique Rolls Royce to a shop to have work done. They always adjusted the clutch with zero free movement at the top. After having to replace the clutch 3 times I finally was able to connect with the owner of the shop and inform him that free movement at the top was absolutely necessary. After that, no more clutch problems. I think they were used to new RR's that had hydraulic clutches.
#5 |
Yes I really don’t like the way it feels. Their is a little free movement as you mentioned
But I prefer the clutch grabbing long before it does. I’ll leave well enough alone for now. |
#6 |
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" ![]() |
