Old 07-01-2025, 12:50 PM   #1
dfairty1
dfairty1's Avatar
Default '30 Model A barely turns over
My '30 A coupe barely turns over & won't start. I have 6.12V at the battery. I pulled both battery terminals & cleaned them. Body Ground seems solid. Pulled starter & bench tested, works perfect. Next steps?
dfairty1 is offline   Reply With Quote
Old 07-01-2025, 12:58 PM   #2
Canton_Model_A's
Canton_Model_A's's Avatar
Default Re: '30 Model A barely turns over
How hard is it to turn over with the crank?
1929 Model A Tudor - "Darla"
'29 Model A: Old enough to start with a crank, young enough to steal the show!
"Stay away from negative people, they have a problem for every solution"
Model A Ford Club of America
Model A Restorers Club
Motor City A's Club
Canton_Model_A's is offline   Reply With Quote
Old 07-01-2025, 01:44 PM   #3
Charlie Stephens
Are your cables large enough? 6 volts uses larger diameter cables. The ones for the auto parts store are sized for 12 volts.
Charlie Stephens
Old 07-01-2025, 01:56 PM   #4
Canton_Model_A's
Can you tell if the cables have been replaced?
Motor City A's Club
Old 07-01-2025, 02:40 PM   #5
ronn
2nd ground to chassis?
Old 07-01-2025, 03:03 PM   #6
dfairty1
dfairty1's Avatar
Not any different than normal.
Old 07-01-2025, 03:06 PM   #7
dfairty1
dfairty1's Avatar
Charlie Stephens
They are quite large. Not sure if they are original, but definitely are not 12V size. It ran perfectly fine for years. It just started acting up last Summer.
Old 07-01-2025, 03:16 PM   #8
dfairty1
dfairty1's Avatar
Where is the seond ground? The one coming off the negative on the battery goes to the chassis behind the battery.
Old 07-01-2025, 03:17 PM   #9
dfairty1
dfairty1's Avatar
Same as it has always been.
Old 07-01-2025, 03:42 PM   #10
Y-Blockhead
Y-Blockhead's Avatar
Have you done a Load Test on your battery. It may be dying. Your favorite battery store should be able to check it for you.
Old 07-01-2025, 03:45 PM   #11
Big hammer
Load test the battery. Local auto parts stores an do the test, most likely for free, less your labor of r&r the battery
I type slower than Y - blockhead :-(
get a bigger hammer tap done
Old 07-01-2025, 03:51 PM   #12
john in illinois
john in illinois's Avatar
The positive terminal of battery should hook to chassis.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 07-01-2025, 04:32 PM   #13
dfairty1
dfairty1's Avatar
John
Previous owner converted it to negative ground system.
Old 07-01-2025, 04:33 PM   #14
dfairty1
dfairty1's Avatar
I bet this is it! Will know tomorrow! Thanks!
Old 07-01-2025, 05:38 PM   #15
nkaminar
nkaminar's Avatar
It can only be the battery, the starter motor, the starter foot switch, the wires, or the connectors. Eliminate one at a time.
Old 07-01-2025, 06:00 PM   #16
dfairty1
dfairty1's Avatar
I have eliminated the rest, so battery it is! Will try a load test tomorrow!
Old 07-01-2025, 06:39 PM   #17
Gary WA
Gary WA's Avatar
Agree! Load Test Battery!!! Easy things first!
www.whidbeymodelaclub.com
Old 07-01-2025, 11:06 PM   #18
ModelA29
ModelA29's Avatar
Harbor Freight has a cheap load tester. https://www.harborfreight.com/100-am...ter-61747.html
Also just don't check that the contacts to the frame and starter are tight. Take them apart and clean them with scotch bright. Corrosion can form between the dis similar metals increasing the resistance.
ModelA29 is offline   Reply With Quote
Old 07-02-2025, 05:15 AM   #19
Marshall V. Daut
Before pulling the battery, turn on the headlights and activate the starter with the ignition OFF. Either you or someone stand in front of the car while this is going on and see if the headlights dim way down as the starter turns. A slight dimming is normal, but if the headlights do dim noticeably and the starter turns the engine over even slower, the battery probably is weak, as has been suggested. Other than problems with the starter itself, this condition could also be caused by a bad ground, although you stated you checked that. You have also verified that the cables are the correct thickness and not auto parts store thin 12-volt cables. With a 6-volt system, good grounds (ground strap and an auxiliary cable) and the correct gauge cables are absolutely essential, something that you might skimp by on using a 12-volt battery. A 6-volt system is less forgiving.
Follow "ModelA29's" suggestion for establishing a good ground to the frame and use an external star lock washer to dig into the crossmember metal. Even though the ground here may look good, the mating area on the crossmember must be shiny down to the metal. I've been fooled by an otherwise clean-looking ground here that affected the starter's operation. Re-check this area and make sure you have the correct braided heavy-duty ground strap and that it is not frayed or corroded from battery acid. Be especially critical where the woven strap enters the attaching end. Often the two are separating from age, battery acid or over-torquing the strap at an odd angle.
Although engine pans only peripherally assist in the electrical system's performance, it's one more area that Ford engineers designed to complete the electrical path throughout the car. I'm not saying a lack of engine pans will cause a starter to turn over slowly. I'm just adding that the engine pans were designed to assist in the overall charging health of a Model A.
Marshall
Old 07-02-2025, 08:29 AM   #20
Bob Bidonde
Bob Bidonde's Avatar
Here is how to install a second ground to the battery.
Bob Bidonde
