Old 06-30-2025, 12:53 PM   #1
randy993
randy993's Avatar
Default Replacement brake light switch
Hello all
Looks like I need to replace my 12v brake light switch on my master cylinder. Any recommendations? Thanks
randy993 is offline   Reply With Quote
Old 06-30-2025, 01:03 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Replacement brake light switch
I use the Harley Davidson motorcycle brake light switch.
Read thru this material:
https://www.fordbarn.com/forum/searc...rchid=45299710
Old 06-30-2025, 02:43 PM   #3
OLDMANKOHOUT
Not for use with silcone brake fluid.
Standard pressure and low pressure switch
https://sacramento-vintage-ford.odoo...r-cylinder-938
OLDMANKOHOUT is offline   Reply With Quote
Old 06-30-2025, 02:54 PM   #4
19Fordy
19Fordy's Avatar
Interesting, I use that switch with silicone brake fluid with no problems.
Old 06-30-2025, 02:56 PM   #5
randy993
randy993's Avatar
I couldn’t get your link to open
Old 06-30-2025, 03:03 PM   #6
randy993
randy993's Avatar
I’m going by Napa tomorrow and see if they have anything. My local napa and oreilly used to carry some older stuff but now if it’s not in the computer they don’t know what it is.
Old 06-30-2025, 03:42 PM   #7
Kube
Kube's Avatar
I bought three in a row at Napa. All three were defective. Drove me near the brink of insanity. Three in a row? I thought that not possible. It is and it was.
Then bought two of these (below) via Amazon. Both worked and continue to work perfectly.
Hydraulic Rear Brake Light Switch DS-272191 Compatible with Harley Davidson Sportster Softail Touring Dyna Super Electra Glide Road King FXR Deluxe Fat Boy Low Rider Heritage 72023-51A
Old 06-30-2025, 04:31 PM   #8
Flathead Fever
Flathead Fever's Avatar
If I remember correctly there is a low pressure and a regular pressure switch that look identical. Seems like there were some peoples brake lights staying on with the low-pressure switch. I'm guessing the residual pressure valve in the master cylinder that holds a little pressure in the system when the car is not in use was just enough pressure to activate the lights. So, if your given a choice of pressures I'd go with the higher pressure of the two sensors. My sister has a '64 1/2 Mustang that still uses a switch that looks just like these, it screws into the master cylinder and works off of hydraulic pressure. In 1965 they changed it to one that mounts on the brake pedal under the dash so I'm guessing '64 was the last year for the hydraulic operated brake light switch.
I've heard of people using the Harley brake light switches, but I've never tried one.
Flathead Fever is offline   Reply With Quote
