Old 06-15-2025, 03:27 PM   #1
KCW
Default 1930 Model A engine running hot
I’ve got a 1930 Model A. When I got it about 8 years ago the previous owner had installed a temperature gauge. It’s underneath the steering column. The engine has been running hot and a friend of mine suggested that perhaps the gauge itself is bad. I was thinking of replacing it. We’ve tried everything else. Attached are a few photos. One is of the gauge itself and another is where it inserts in the engine. Not really sure how it work. Does anyone know where I might get a similar one to swap it out and where? I can’t imagine it’s that difficult to install. Thank you everyone!!!
PS. Drove for ten minutes the other day and the engine read 210degF. Spark was timed appropriately.
KCW is offline   Reply With Quote
Old 06-15-2025, 03:39 PM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: 1930 Model A engine running hot
Can you stick a thermometer in the radiator neck to check how hot it really is?
Old 06-15-2025, 04:24 PM   #3
nkaminar
nkaminar's Avatar
Take the probe out and stick it in boiling water. You can use a hot plate in the engine compartment. It should read 212 F. Or stick it in hot water with an accurate thermometer in the same water. They should read the same temperature.
nkaminar is online now   Reply With Quote
Old 06-18-2025, 04:14 PM   #4
Wick
Wick's Avatar
You can use a temperature gun to check it. I don't care for the temp. Guage, I'm old school...if the engine smells funny, can't touch the head then it's hot. If you hear the radiator gurgling, it's hot.
If the exhaust manifold is white or you hear the engine ticking when its off, it's hot.
After a ride you should be able to touch the dip stick, carburetor and top of hood.
I do know the engine will run 10 degrees cooler with the engine pans installed.
Wick is offline   Reply With Quote
Old 06-18-2025, 07:11 PM   #5
Ayers1
Ayers1's Avatar
You can get a universal temperature gauge at any auto parts store. I had to replace one on mine and the one I bought had different threads on it. I then had to go back and get an adapter for it. That also comes as a universal kit.
As to why it's getting hot, if your timing and fuel is set properly, check the radiator. A lot of the tubes could be stopped up and the water isn't flowing like it needs to.
Steve,
Proud owner of
28 Fordor, been in family since 63
30 Tudor
31 S/W Town Sedan
Skyline Chapter MAFCA, MARC
Ayers1 is offline   Reply With Quote
Old 06-18-2025, 07:34 PM   #6
nkaminar
nkaminar's Avatar
Wick brought up the use of an IR gun. This is a good tool to measure different parts of the engine and cooling system. The head will run a different temperature than the temperature of the exiting coolant. It will also measure a different temperature fore and aft. The IR gun can be used to diagnose problems with the radiator such as clogged tubes.
Old 06-18-2025, 08:57 PM   #7
CT Jack
CT Jack's Avatar
Another thought is have you checked your timing? Maybe you are running too retarded which could affect engine temperature.
CT Jack is offline   Reply With Quote
Old 06-18-2025, 09:14 PM   #8
mcgarrett
Unless I missed it, you didn't mention if it's spitting hot water or steam out the radiator overflow tube. The old-timers used to say if it's not shooting water on the ground it's not overheating.
As Wick previously mentioned, if you hear a gurgling/boiling sound under the hood that's a good indication you're overheating.
mcgarrett is offline   Reply With Quote
Old 06-18-2025, 09:35 PM   #9
1crosscut
1crosscut's Avatar
See post #2.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
