Old 06-13-2025, 09:23 PM   #1
JohninKuranda
JohninKuranda's Avatar
Default Fuel Shut-off valve
I am just after clarification as to the thread size on the carb-mounted fuel shut-off valve (the thread marked in purple on the attachment). I am thinking that it is 1/2" - but wondering if it is UNF or NPT? Or is it another size?
Many thanks
John
JohninKuranda is offline   Reply With Quote
Old 06-16-2025, 10:03 AM   #2
redmodelt
redmodelt's Avatar
Default Re: Fuel Shut-off valve
1/2" (US) national fine straight thread.
Old 07-01-2025, 09:00 PM   #3
Daisyarney
It’s most likely 1/2" NPT, since most carb-mounted fuel shut-off valves use tapered threads for sealing. However, to be sure, you could measure the thread diameter and pitch with a gauge or check the carb model’s spec sheet. Did you already check if it has a slight taper (NPT) or straight thread (UNF)?
unblocked doodle jump
Daisyarney is offline   Reply With Quote
Old 07-03-2025, 10:48 AM   #4
redmodelt
redmodelt's Avatar
No it is a straight thread and uses packing to seal or in some cases a brass ferrule. The other end that fits into the carb is pipe thread.
