#1 |
I saw two Snap-on S-8663 Model A Obstruction Head nut wrenches on e-bay today for good prices if anyone is interested. Not mine.
One looks really nice date coded 1959. https://www.ebay.com/itm/297388963592. The other has some wear, date coded 1954. https://www.ebay.com/itm/236141745480. |
#2 |
What's an obstruction wrench? I was a truck mechanic for 20 years and never heard that description before.
#3 |
It is a wrench that is bent to fit around obstructions so you can get the proper torque on the fastener. In this case the Model A distributor and carburetor.
I just looked it up in my 1980 Snap-on Catalog, Called a Cylinder Head Wrench/Torque Adaptor. "Designed for getting around obstructions and reaching into restricted areas when removing or torquing cylinder heads. The nice one I referred to already sold. Last edited by Y-Blockhead; 06-12-2025 at 01:21 PM. |
#4 |
I picked up one of these at an estate sale. Still sealed in the original package $5.
https://www.ebay.ca/itm/151574867052 I had been using my aircraft cylinder wrenches but they are pretty tall. I also bought one of these little electronic torque wrenches at HF for the road tool kit. |
#5 |
Another picture of a Snap-On S-8663-B Obstruction Wrench.
#6 |
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 06-12-2025 at 06:00 PM. |
#7 |
Home made 11/16 box end open end combination wrench - nkaminar |
#8 |
Is that a piece of heavy angle between the wrench parts?
#9 |
#10 |
Snap-On (especially old) stuff is lovely. I have a few. But as far as the head torque adapter, hard to beat the one Snyder's sells.
BTW, when I was growing up we knew these distributor wrenches, designed to get around the distributor body and to the bolt that was loosened to adjust timing.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#11 |
Just wondering- has anyone ever done a test to see if these angles affect the torque value at all?
Brian SATX |
#12 |
The socket portion of the adapter is directly in line with the square hole for the torque wrench. No lateral displacement = no change in torque value.
#13 |
I have a few of those.We always called them torque adapters.Lots of farm and industrial equipment are built with a need for them.Continental and Perkins have head nuts tucked in between the pushrod tubes.Case had an odd casting overhang that required the use of them.On a John Deere engine mounted on an industrial stand you can't tighten the front main bolts without one of those.The smaller ones I kind of consider distributer and vacuum pump wrenches.The 11/16 through 1-1/8 are much beefier,and used for heads and mains.Instead of buying the whole set over 40 years ago,I bought one at a time as needed,and now I have the whole set.Probably cost me double that way.
#14 |
Bruce, Square tubing. Any tubing will carry more torque than any angle iron. I had to bend the wrench parts to get everything in alignment because I was using it with a torque wrench. The wrench parts have to be heated to dull red to bend.
#15 |
#16 |
i dug around in the junk and came up with some old broken sockets and some 5/16 x 1 flat bar and fabricated mine. you can pickup used sockets at a yard sale or flea market and make one cheap. i like fabricating my own A tools when i can, certain satisfaction in doing so. i even copied a rear brake drum puller a friend had made years ago. it is simple but does a good job.
#17 |
I've got several of the genuine Snap-On tools, $50 post paid to anywhere.
#18 |
Pretty much all of the aircraft engine manufacturers used the odd shapped tools such as these to remove various assemblies such as cylinders, tappet blocks , and even push rod tubes from the old radial engines as well as the opposed types. They were very common in aviation. Lycoming and Continental still use them.
#19 |
I have several snap on tools can somebody explain how you read the date on them.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
#20 | |
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 06-14-2025 at 10:14 AM. Reason: Correction |
