Old 06-07-2025, 05:42 AM   #1
Lenny Bruce
Default Roadster Top issues
Hello good morning,summer is finally here and so are all my questions LOL
We picked up a nice ‘30 Roadster last year. The previous owner
Had a new top installed. It was closed properly when we got the car but now it won’t fasten correctly. The two pins that insert into the windshield frame won’t line up. One will go in perfectly but the other one will not. It’s driving me crazy because I know they did at one point. Is their a trick to this I’m missing?😳
Lenny Bruce is offline   Reply With Quote
Old 06-07-2025, 06:03 AM   #2
brokenspoke
Default Re: Roadster Top issues
A picture would help
brokenspoke is offline   Reply With Quote
Old 06-07-2025, 07:36 AM   #3
springerpete
springerpete's Avatar
Are all the rear snaps fastened, might try loosening them and let the car sit in the hot sun till the top gets warm and soft.
If the side-to-side spacing of the front fasteners are wrong you'll have to make adjustments.
springerpete is offline   Reply With Quote
Old 06-08-2025, 06:53 AM   #4
Lenny Bruce
I will check that thank you
Old 06-08-2025, 09:29 AM   #5
Planojc
Planojc's Avatar
Loosen the wing nuts on the stanchion, insert it in the header hole and tighten the wing nuts back up.
Planojc is online now   Reply With Quote
Old 06-09-2025, 09:16 AM   #6
old31
Sometimes those 2 pins can be a problem. Especially if the car is not sitting level. As planojc mentioned, loosen all the nuts on the windshield so that you can move it as needed, then align the 2 pins, then tighten the windshield back up.
Before you tighten the windshield up, now is the time to snap the 5 upper snaps of the soft top to the car. It is easier to get your fingers in there before everything is tight.
Old 06-09-2025, 05:06 PM   #7
Lenny Bruce
Gotcha we will definitely try that thank you very much!
